Warning: mail() [function.mail]: Failed to connect to mailserver at "localhost" port 25, verify your "SMTP" and "smtp_port" setting in php.ini or use ini_set() in C:\Archivos de programa\xampp\htdocs\mailer.php on line 58
Warning: Cannot modify header information - headers already sent by (output started at C:\Archivos de programa\xampp\htdocs\mailer.php:58) in C:\Archivos de programa\xampp\htdocs\process.php on line 169
the mailer.php file contains both mails the one it is send when you register and the one it is send when you change your password.
and goes like this:
* Mailer.php
* The Mailer class is meant to simplify the task of sending
* emails to users. Note: this email system will not work
* if your server is not setup to send mail.
class Mailer
* sendWelcome - Sends a welcome message to the newly
* registered user, also supplying the username and
* password.
function sendWelcome($user, $email, $pass){
$from = "From: ".EMAIL_FROM_NAME." <".EMAIL_FROM_ADDR.">";
$subject = "my site - Welcome!";
$body = $user.",\n\n"
."Welcome! You've just registered at my Site "
."with the following information:\n\n"
."Username: ".$user."\n"
."Password: ".$pass."\n\n"
."If you ever lose or forget your password, a new "
."password will be generated for you and sent to this "
."email address, if you would like to change your "
."email address you can do so by going to the "
."My Account page after signing in.\n\n"
."- Atte: me";
return mail($email,$subject,$body,$from);
* sendNewPass - Sends the newly generated password
* to the user's email address that was specified at
* sign-up.
function sendNewPass($user, $email, $pass){
$subject = "my site - Your new password";
."We've generated a new password for you at your "
."request, you can use this new password with your "
."username to log in to mysite .\n\n"
."New Password: ".$pass."\n\n"
."It is recommended that you change your password "
."to something that is easier to remember, which "
."can be done by going to the My Account page "
."after signing in.\n\n"
."- Atte: Me";
/* Initialize mailer object */
$mailer = new Mailer;
this is the prosses.php part of the code that get the mail done.
* procForgotPass - Validates the given username then if
* everything is fine, a new password is generated and
* emailed to the address the user gave on sign up.
function procForgotPass(){
global $database, $session, $mailer, $form;
/* Username error checking */
$subuser = $_POST['user'];
$field = "user"; //Use field name for username
if(!$subuser || strlen($subuser = trim($subuser)) == 0){
$form->setError($field, "* Username not entered<br>");
else{
/* Make sure username is in database */
$subuser = stripslashes($subuser);
if(strlen($subuser) < 5 || strlen($subuser) > 30 ||
!eregi("^([0-9a-z])+$", $subuser) ||
(!$database->usernameTaken($subuser))){
$form->setError($field, "* Username does not exist<br>");
/* Errors exist, have user correct them */
if($form->num_errors > 0){
$_SESSION['value_array'] = $_POST;
$_SESSION['error_array'] = $form->getErrorArray();
/* Generate new password and email it to user */
else{
/* Generate new password */
$newpass = $session->generateRandStr(8);
/* Get email of user */
$usrinf = $database->getUserInfo($subuser);
$email = $usrinf['email'];
/* Attempt to send the email with new password */
if($mailer->sendNewPass($subuser,$email,$newpass)){
/* Email sent, update database */
$database->updateUserField($subuser, "password", md5($newpass));
$_SESSION['forgotpass'] = true;
/* Email failure, do not change password */
else{
$_SESSION['forgotpass'] = false;
header("Location: ".$session->referrer);
thanks in advance
