AdSense help
3 replies to this topic
#1 Evolution68
  • 24 posts
Posted 17 October 2006 - 01:34 PM
on my blog i have recantly put up some adds by google, its set up and everyting. So i wait a cuple of days and guess how much money i have, yup $0 and i know for a fact that atleast one person has clicked on the adds, my friend, he told me that he had, i did not tell him to click on it, and i dought hes lying about it as he is a close friend and isnt the sort to do that. ive checked everything and it seems to be working fine, acording to google. But my money isnt going up. WHAT SHOULD I DO?
#2 cheerio
  • 246 posts
Posted 17 October 2006 - 01:51 PM
Give it some time. It's not so easy to get alot of money from google ads anyways. Sometimes you might get lucky and land on the best setup without knowing it, but most the time you don't get good click ratios, or you get banned :)
#3 rc69
    PHP Master PD
  • 3,827 posts
  • Interests:Web Development
Posted 17 October 2006 - 02:56 PM
You should contact google about this. But just so you know, i've had google ad's for little over 2 years and don't even have $20 yet. So don't expect a whole ton of money.
#4 Loadboy
  • 20 posts
Posted 17 October 2006 - 03:48 PM
Hello Evolution68,
Theres a lot of factors that need to be considered to determine whether adsense is a good choice or not. For starters, how new is your site? If it's under 6 months old, it may still be "sandboxed". Have you added to much new content to fast? Yuppers... that gets sandboxed also!
How many unique visitors do you receive each month? Traffic is what you need most to make money with adsense.
Do the ads match the content on the page? (if not look up "section targeting" for adsense on goog). IF the ads are on target and they match your visitors interest, you should get clicks.
If the case of the click that you do know about, often times goog will hold some of the clicks for manual verification. If it passed there inspection, you get what is known as a "click dump" usually sometime during the month.
Ad positioning is EVERYTHING with adsense. Forget the "heat map". What works on some sites doesn't work on others. Experiment with the different ads/colors/etc. It doesn't take much to pull at least the bare miminum to recieve a check every month once you find the "hot spot" for your particular site.
Not sure if anything I've wrote will be of any help to you, or maybe you already know about this stuff, either way, best of luck to you.
