Problem loading xml into dynamic field
2 replies to this topic
#1 Lady Ramses
  • 5 posts
Posted 26 October 2006 - 09:43 PM
I can't seem to get the xml to load into a dynamic field.
here is my actionscript:
rssURL = "feed url here";
function loadRSSfeed() {
// set xml object
var thisrssfeed = new XML();
thisrssfeed.ignoreWhite = true;
thisrssfeed.contentType = "text/xml";
thisrssfeed.onLoad = function(success) {
if (success) {
processxml(thisrssfeed);
// do stuff
for (var j = 1; j<6; j++) {
trace(_root["RSSItem"+j].feedTitle);
trace(_root["RSSItem"+j].feedUrl);
if (_root["RSSItem"+j].feedDescription != undefined) {
trace(_root["RSSItem"+j].feedDescription);
trace(_root["RSSItem"+j].feedDate);
trace(_root["RSSItem"+j].feedGuid);
trace("----------");
} else {
// do error handling
thisrssfeed.load(rssURL+"&uniq="+new Date().getTime());
function processxml(thisxml) {
var thisxml = thisxml.firstChild.firstChild.childNodes;
// this first five attributes aren't required:
for (i=5; i<10; i++) {
node = thisxml[i];
_root["RSSItem"+(i-4)] = new Object();
_root["RSSItem"+(i-4)].feedTitle = node.childNodes[0].firstChild.nodeValue;
_root["RSSItem"+(i-4)].feedUrl = node.childNodes[1].firstChild.nodeValue;
_root["RSSItem"+(i-4)].feedDescription = node.childNodes[2].firstChild.nodeValue;
_root["RSSItem"+(i-4)].feedDate = node.childNodes[3].firstChild.nodeValue;
_root["RSSItem"+(i-4)].feedGuid = node.childNodes[4].firstChild.nodeValue;
loadRSSfeed();
stop();
I have used: _root["RSSItem3"].feedTitle in the Var field as well as the instance
why is it now pulling the data?
thanks in advance!
#2 funkysoul
    The Funky Stuff
  • Publishing Betazoids
  • 2,307 posts
Posted 29 October 2006 - 09:14 AM
remove the variable from the textfield and give it an instance name of : feedTitle, feedUrl and so on...
#3 Lady Ramses
  • 5 posts
Posted 29 October 2006 - 01:05 PM
how would i tell it which title to pull? i have 5 titles
i tried just adding the feedTitle but it still shows up blank
i attached the file i am using.
thanks so much for replying!
