led audio meter in cinema 4d
3 replies to this topic
#1 troytan
  • 1 posts
Posted 02 November 2006 - 07:19 PM
i want to create a led audio meter in cinema 4d the bars that go up and down when music playing like what u would see on your car sterio do any body have any idea how to do it
#2 NGPixel
    Senior Programmer
  • 1,410 posts
  • Interests:Web Design : Coding : Animation
Posted 02 November 2006 - 11:08 PM
It would be easier and faster to create this effect in After Effects instead...
#3 Scythar
    Honored X Staff
  • 1,888 posts
Posted 03 November 2006 - 12:28 PM
Or 3DSmax also got this possibility. --> what you need is an "event controller"
#4 ink_n_paint
  • 2 posts
Posted 13 November 2006 - 01:06 AM
Do you want this to fit a particular tune or be driven to any audio plugged in?
The MOGRAPH plugin would handle an audio triggered effect.
You can also make a simple 2d animation of the display, create an alpha that you can animate and project it onto the surface (tile switched off in flat projection mode, scale to fit). this would give you the ability to use the shader effects like luminosity and glow..
There's probably a million ways to do this inside C4D without having to resort to external software!
