Forum coding problem (add reply part)
7 replies to this topic
#1 AnonyDeath
  • 6 posts
Posted 11 November 2006 - 12:29 PM
(database details have been removed)
Full code to add reply:
// Connect to server and select databse.
mysql_connect("$host", "$username", "$password")or die("cannot connect");
mysql_select_db("$db_name")or die("cannot select DB");
// Get value of id that sent from hidden field
$id=$_POST['id'];
// Find highest answer number.
$sql="SELECT MAX(a_id) AS Maxa_id FROM $tbl_name WHERE question_id='$id'";
$result=mysql_query($sql);
$rows=mysql_fetch_array($result);
// add + 1 to highest answer number and keep it in variable name "$Max_id". if there no answer yet set it = 1
if ($rows) {
$Max_id = $rows['Maxa_id']+1;
else {
$Max_id = 1;
// get values that sent from form
$a_name=$POST['a_name'];
$a_email['a_email'];
$a_answer['a_answer'];
$datetime=date("d/m/y H:i:s"); // create date and time
// Insert answer
$sql2="INSERT INTO $tbl_name(question_id, a_id, a_name, a_email, a_answer, a_datetime)VALUES('$id', '$Max_id', '$a_name', '$a_email', '$a_answer', '$datetime')";
$result2=mysql_query($sql2);
if($result2){
echo "Successful<BR>";
echo "<a href='view_topic.php?id=".$id."'>View your answer</a>";
// If added new answer, add value +1 in reply column
$tbl_name2="forum_question";
$sql3="UPDATE $tbl_name2 SET reply='$Max_id' WHERE id='$id'";
$result3=mysql_query($sql3);
else {
echo "ERROR";
mysql_close();
I seem to have a problem with the following line(s?):
I am new to PHP and I would love to figure this one out, so I can continue with my forum. ^^;
The error:
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in /home/httpd/vhosts/*********/subdomains/********/httpdocs/!forum/add_reply.php on line 18
ERROR
#2 cheerio
  • 246 posts
Posted 11 November 2006 - 01:27 PM
$a_name = $_POST['a_name'];
$a_email = $_POST['a_email'];
$a_answer = $_POST['a_answer'];
Also you need to set the $tbl_name variable
Edited by cheerio, 11 November 2006 - 01:27 PM.
#3 AnonyDeath
  • 6 posts
Posted 11 November 2006 - 01:35 PM
Thanks for your help.
But.. I'm clueless as to where to put the $tbl_name variable.
#4 Mr. Matt
    Moderator
  • 1,945 posts
  • Gender:Not Telling
Posted 11 November 2006 - 01:42 PM
can go here:
$tbl_name = 'table_name';
$id=$_POST['id'];
I would also tidy up that query:
"SELECT MAX(`a_id`) AS `Maxa_id` FROM `".$tbl_name."` WHERE `question_id` = '".$id."'"
Matt
#5 AnonyDeath
  • 6 posts
Posted 11 November 2006 - 02:03 PM
Hmm... with all the changes, I still get the exact same error. o.O;
#6 rc69
    PHP Master PD
  • 3,827 posts
  • Interests:Web Development
Posted 11 November 2006 - 02:09 PM
So, rather then throwing darts blindly, lets narrow the problem down.
Find all instances of mysql_query(); in there, and add some error handling. Like so:
mysql_query($sql);
// Change to
mysql_query($sql) or die(mysql_error());
#7 AnonyDeath
  • 6 posts
Posted 11 November 2006 - 03:06 PM
mysql_query($sql);
// Change to
Result: Unknown column 'a_id' in 'field list'
and when I changed some things: Unknown column 'question_id' in 'where clause'
#8 Demonslay
  • 970 posts
Posted 11 November 2006 - 03:12 PM
Ok, now echo your SQL statement before sending it to the mysql_query() function, and double-check your table to make sure the columns exist.
