need help with adobe photoshop
Started by Bombefar, Nov 19 2006 07:54 AM
7 replies to this topic
Posted 19 November 2006 - 07:54 AM
hi! i need help with my adobe photoshop?? i cant use the keyboard when i use it:S i want to use shortcuts with the keyboard.. so can anyone help me?
Posted 19 November 2006 - 12:13 PM
Go to Edit > Keyboard Shortcuts. You can define them there.
Posted 19 November 2006 - 04:00 PM
Yeah, but only in PS CS2 (I don't know if PS CS allow you to customize them too, but PS 7 don't)
Bombefar: so if you press for example Ctrl + T in your keyboard when using Photoshop, it doesn't work?
Posted 19 November 2006 - 04:25 PM
yep it can,
there's even a shortcut for that
alt+ctrl+shft+K
alt+ctrl+shft+K
Posted 21 November 2006 - 08:21 AM
[/quote]
ctlr + t doesn't work either.. nothing works :wacko: what can i do with it? can i activate it??
alt+ctrl+shft+K does not work:P
[/quote]
Edited by Bombefar, 21 November 2006 - 08:23 AM.
#6
Posted 21 November 2006 - 10:53 AM
If you go to the edit menu --> can you see the Keyboard Shortcuts" item (it's the third last item in the menu i think) ?
If so, what you see when you click on that one.
#7
Posted 22 November 2006 - 08:19 AM
keyboard shortcuts and menus just coming up..
#8
Posted 22 November 2006 - 11:04 AM
Let's compare those a little:
watch this pic and try to see if you can get exacly the same.
And when there's something you want a shortcut for try to find the item and try to change a shortcut:
we'll start with the shortcut for bringing up the shortcut menu (oh boy, the older i get the stupier my jokes are getting):
AND? You see the same?
Cos if you do i am afraid it has nothing to do with photoshop, but with
a) some keyboard button not working
somehow you type too fast r something, thus not holding down all the buttons together at some point.
... r something else we'll have to find somehow.
