cant see the image
nvm i lusked abit and you are following this tut correct?
http://www.flash-game-design.com/tutorials...p-tutorial.html
To add inbetween frames to the noise is easy, you just create more frames with images you want to show (like in step 4) in the same area as the noise and put it so that imageready shows those images on certain frames just like in step 7 of the tutorial. And have the noise blend with those frames. You can have more then one layer showing at a time on every frame so if you put the images you want the screen to display undearneath certain frames of the noise and put the noise on for example screen or lighten blending mode and have the four noise frames loop over a longer animation you could get a neat result.
Edited by Dance, 08 December 2006 - 04:23 PM.
