Tutorials links ?
Posted 31 December 2006 - 08:36 AM
on my tab bar i`m using FF 2.0.0.1 also it`s not working with IE7 ?
Posted 31 December 2006 - 04:42 PM
Posted 31 December 2006 - 06:49 PM
Posted 31 December 2006 - 08:22 PM
Looks like your computer has some bugs. You should run virus and adware check...
done and there is nothing wrong
Example: Modern Animated TV - Learn how to draw a TV with animated static in Photoshop tutorials when i click on it or hover over it the link that appears is this http://www.pixel2lif...nimated_static/
i can`t see a .Html ,.asp or whatever as far as i know it must conatain something like this at the end (maybe i`m wrong i`m not an expert )
Edited by gaga, 31 December 2006 - 08:30 PM.
Posted 31 December 2006 - 08:46 PM
Do you have another computer you can try it on? I would have said as most people would that this is a cache issue however you have tried it in all browsers? I assume you have tried clearing your cache?
#6
Posted 31 December 2006 - 09:38 PM
#7
Posted 01 January 2007 - 05:28 AM
@Zero.Dub: unfortunately i don`t have another computer , and it`s the 1st time that this problem happens to me
the main problem is between me and P2L cause when i go to the tutorial site the main site it`s working but i can`t get a direct link from P2L to the tutorial i have to go the main site of the tutorial and search for it .
Edited by gaga, 01 January 2007 - 05:32 AM.
#8
Posted 01 January 2007 - 07:36 AM
it`s still not working with FF , IE7 & Opera 9.10
#9
Posted 01 January 2007 - 01:41 PM
i can`t view any tutorials all i get is this
Go to your internet properties - settings and check them all. Enable images for one. There's another topic in here where a member had exactly the same problem btw
#10
Posted 01 January 2007 - 06:13 PM
what settings in the internet properties cause it has many tabs ?
#11
Posted 03 January 2007 - 05:07 AM
#12
Posted 03 January 2007 - 07:19 AM
Tools -> Options -> Content -> Load images automatically (tick)
If you are using Internet Explorer:
Tools -> Internet Options -> Advanced -> Multimedia(-Show images)
Edited by Matthew., 03 January 2007 - 07:19 AM.
#13
Posted 03 January 2007 - 01:24 PM
Gaga, if you are using Firefox go to:
Thanks but the problem still exists
#14
Posted 03 January 2007 - 01:41 PM
#15
Posted 03 January 2007 - 04:09 PM
Have you tried the smiple things such as reinstalling the browsers?
yes
@ Donna : Ok thanks , Btw do u know the guy that had the same problem before so i can ask him maybe he has the answer ?
#16
Posted 03 January 2007 - 04:14 PM
#17
Posted 03 January 2007 - 08:32 PM
There's was fixed when they enabled images, via their browser. That doesn't work for you so best to speak with your ISP.
ok thanks
#18
Posted 19 January 2007 - 06:16 AM
are corrupted.
This happened to me once in Windows XP, and your browser ends up not knowing how to handle the
URLs you give it.
For me, in IE, i would ask if i wanted to download the file, or choose something to open it with.
Other times it gave a blank screen.
#19
Posted 19 January 2007 - 09:16 AM
Dan
