I created my layout for my website in Photoshop. Then I brought it over to Dreamweaver to code it all. The thing is when I bring it into DW and preview the site there are white spaces all around it. I found out a background color code and put the bg color as the bg of the layout. Everything worked fine and there were no more white spaces. But then the layout did not stretch to the full top or bottom of the page. Here is a link so you can see what I mean. http://k1net1cgaming...l1nch/home.html. As you can see if you look at the top and bottom, the layout is missing. Is there a way I can stretch the layout out so it will fit to the bottom and top of the page?
Thanks
no one has had this problem or knows how to fix it?
Layout Problem
Started by pistonsfreak, Dec 31 2006 11:54 AM
1 reply to this topic
Posted 31 December 2006 - 11:54 AM
Posted 01 January 2007 - 03:17 PM
Piston, this is the 3rd topic on the page, there is no need to bump and no need to hijack others posts with your problem. If nobody has answered in a day or so, then you'll either have to wait, or do some research of your own.
You're problem is quite freqently asked and google will return 100's of results for you. First, you need to set the body's margin/padding to 0, then you need to look around (the forum for almost a hundred results) for css height problems.
