Help with coding site.
3 replies to this topic
#1 iPixeL.
  • 70 posts
Posted 12 January 2007 - 05:55 AM
Well, this sounds a little easy, but for some reason I have difficulty putting text on top of my template that I create in Photoshop CS2. When I create a template in PS, I export if for the web through the app and it creates the HTML file and Images in a subfolder for me. However, whenever I create text by simply creating a layer, it is always out of place in the browsers. I have tried using the tutorials by using tables, but dreamweaver spaces out my images too far apart and it doesn't match up in the end.
Please help?
-Tom
Here is how it looks in dreamweaver. I created a layer over my layout, and I have inserted tables within that layer. Please explain why this happens and how I can fix it.
Edited by iPixeL., 12 January 2007 - 02:02 PM.
#2 Jakespikey
  • 44 posts
Posted 12 January 2007 - 07:46 AM
I haven't been doing much on codeing templates for a while... but I'm pretty sure the problem is with your cells in your tables the cell padding would most likely need to be set to 0 for the gaps to be removed... hope that helps.
#3 iPixeL.
  • 70 posts
Posted 12 January 2007 - 12:19 PM
hmmm, no cellpadding and cellspacing is set to 0. The gaps are only filled when I merge the cells, but then the layout of the images gets messed up. Anyone else?
**Updated with pictures of my problem**
Edited by iPixeL., 12 January 2007 - 02:00 PM.
#4 rc69
    PHP Master PD
  • 3,827 posts
  • Interests:Web Development
Posted 13 January 2007 - 01:20 AM
The simple solution would be to not use photoshop or dreamweaver. Do a forum search and you'll find out why.
Try just moving the layer 5-10px to the right and seeing what happens. Other then that, my best suggestion would be to NEVER save a template for web from photoshop, and NEVER use a WYSIWYG editor to code the template for you. Learn to code by hand.
Edited by rc69, 13 January 2007 - 01:20 AM.
