Hi everyone,
I want to create two preloaders that are side by side and one with go faster than the other.
Does anyone know what scripting is involved in order to make one go fast than the other and having them running together at the same time without it conflicting one another?
Preloader Speed
Started by Jas, Jan 31 2007 04:05 AM
4 replies to this topic
Posted 31 January 2007 - 04:05 AM
Posted 31 January 2007 - 09:51 AM
Are they preloading the same thing? Are they supposed to finish at the same time?
Posted 31 January 2007 - 12:05 PM
Well, maybe I used the wrong word but I'm not actually looking to preload anything.
It's pretty much just an animation but I guess what I want to do reminded me of a preloader.
Here is a link to an example of what I want to do:
http://www.bulldogbroadband.com/residentia...g/speeddemo.asp
I pretty much need to create the so called preloader/progress bar to show a comparison.
Hope that makes sense
Posted 31 January 2007 - 12:39 PM
Oh, in that case you can just make two movieclips with the tweened animation inside. Insert a bunch of frames into the longer animation and it will take more time to animate down. If you want a little counter like that, its not too difficult. Just a bit of code.
Posted 07 February 2007 - 06:41 AM
Like the animation, as shown in the link on my last post, I want the speed of the animation to be accurate so it shows the exact timing.
I would have thought that in order to do that there would need to be a lot more coding involved.
Well I guess I could try that out.
Thanks.
Thanks.
