Ok so like the only coding experince I have is html. I am here looking if someone can help me with PHP. I want to make a log in system on the main site page/template and I want it to work with the same log in info as my IPB forums. I would also like to have it extract stuff from certain forums and display it. I have no idea on how to do this but I seen alot of sites that have this and know its PHP. So I am here asking for someones help. I can be reached on the following.
Aim: EnvoyXC
MSN: Cuddlewithjoe@hotmail.com
Need Help Bad
Started by AirBrushing, Feb 05 2007 11:23 AM
3 replies to this topic
Posted 05 February 2007 - 11:23 AM
Posted 05 February 2007 - 11:44 AM
Well, as usual, a simple couple-seconds search would yield infinite knowledge, lol.
Login Systems
And since you are wanting to work with the IPB system, you can either use IPBSDK (very easy to use, recommended), or you can try to make your own class.
Either way is quite simple and basic.
Login Systems
Posted 05 February 2007 - 12:22 PM
Thank you I have no clue what that is cause I dont know any PHP lol I am looking for someone to do so.
Posted 07 February 2007 - 12:12 AM
This is a frequently asked question please use the forum search.
ipb sdk should yeild some good results.
