3D Studio Max -> After Effects 7.0
1 reply to this topic
#1 iFantasmic
  • 1 posts
Posted 12 February 2007 - 07:13 PM
Hi, nice forums here. =]
I was wondering if it possible to take a 3D image/animation from 3D Studio Max and export it to After Effects 7.0? I was hoping I could also (if it is possible to import into AE) enable 3D capabilties for it while inside AE and use cameras.
Thanks!
#2 Stu
  • Publishing Betazoids
  • 1,761 posts
Posted 13 February 2007 - 02:59 PM
im no expert with AE by any means, but what i usually do is render the animation frame by frame and save them in a folder by themselves then import the folder into AE/premiere/whatever, this gives you more control ive found than rendering the animation as a movie file... so yes it is possible to export your max animation to AE. if thats what you meant?
as far as importing your actual .max model into AE, i think the answer is no. if he doesnt pop in and see this thread, ill try point tiago here for you when i next see him online, he will be able to give you a better answer.
