please help with matrix text effectt
8 replies to this topic
#1 bluelad
  • 4 posts
Posted 22 February 2007 - 10:08 AM
Please help me to get that text effect " Everything that has beginnig.......". Find the image in the attachment
thanks
#2 bĘko
  • 477 posts
Posted 22 February 2007 - 10:45 AM
dude, there are a million of tutorials, and im pretty confident that in between them here at P2L, theres also a tutorial on matrix text effect.
#3 bluelad
  • 4 posts
Posted 22 February 2007 - 12:47 PM
please guide me to one tut that can give the same effects
#4 bluelad
  • 4 posts
Posted 27 February 2007 - 03:26 PM
HELP PLEASE...........
#5 Scythar
    Honored X Staff
  • 1,888 posts
Posted 28 February 2007 - 12:38 PM
Something like this? -->
Attached File  Matrix.jpg   87.18K   89 downloads
#6 john7911
  • 10 posts
Posted 02 March 2007 - 08:22 AM
there are some tutorial here ;)
http://www.pixel2lif...rch/4/matrix/1/
#7 gmb
  • 5 posts
Posted 02 March 2007 - 09:05 AM
first you would need the right font... I used OCR-A BT
type yr wording (use a very light green), add a drop shadow (layer style), change blending mode to normal, distance "0", size "6" and make it a darker green.
duplicate layer, set underneath TYPE layer and rasterize it. Then Filter>Blur>Gaussian Blur and use a setting that works for u. It might be a bit light, so then just duplicate the layer again and u should get the effect displayed below
hope this helped
GMB...
Attached File  SAMPLE.jpg   3.38K   61 downloads
#8 jlangholzj
  • 1 posts
Posted 15 March 2007 - 07:27 PM
how about the part on the bottom that says, "matrix revolutions", im haveing a hrad time trying to find one.
#9 Dance
  • 871 posts
Posted 15 March 2007 - 07:32 PM
Type the text
Duplicate the text layer
Rasterize it
go to filter<blur<motion blur
enter a arbitrary value at 0 degree angle
done
