How get random letter with Flash mx?
9 replies to this topic
#1 napalias
  • 5 posts
Posted 14 March 2007 - 03:55 PM
How get random letter with Flash mx? I want create movie symbol with this letter.
#2 Ben
    P2L Jedi Master
  • Publishing Betazoids
  • 1,366 posts
Posted 15 March 2007 - 03:39 PM
Well, you could make a blank dynamic textbox, and call it's instance "randTxt". Then, in the first frame:
function randomise() {
		var charStr:String = "ABCDEFGHIJKLMNOPQRSTUVWXYZ";
		randTxt.text = charStr.charAt(random(charAt.length-1)+1);
Then execute the function whenever...
randomise();
#3 neutron
  • 12 posts
  • Interests:flash, photography, travel, games
Posted 16 March 2007 - 03:20 AM
Idea is ok, but will not work in MX, since this is as2 code.
#4 napalias
  • 5 posts
Posted 16 March 2007 - 03:55 AM
need static not dynamic text beacause want in motion tween change alpha color.
#5 Pax
  • 911 posts
Posted 16 March 2007 - 07:54 AM
AS1 code:
		var charStr = "ABCDEFGHIJKLMNOPQRSTUVWXYZ";
	   trace(charStr.charAt((Math.random()*charStr.length-1)+1));
randomise();
Flash MX (or Flash 6) was the first version of Flash to have Actionscript 2. You cannot modify the text in static text during runtime. If you want to animate your dynamic text, put it inside a movieclip and animate that movieclip.
Edited by Pax, 16 March 2007 - 07:55 AM.
#6 napalias
  • 5 posts
Posted 16 March 2007 - 01:13 PM
i'm try but not wirking with change alfa, just movie from A to B bu not blur
#7 Pax
  • 911 posts
Posted 16 March 2007 - 02:16 PM
Blur is a flash 8 thing. If youre using MX it wont work. Without seeing the .fla, it will be difficult to really see what you need.
#8 napalias
  • 5 posts
Posted 17 March 2007 - 06:46 AM
if text is static i'm change alfa color ant text disapear.
#9 Pax
  • 911 posts
Posted 17 March 2007 - 09:08 AM
Put the dynamic text inside a movie clip and embed the font. Then your animations will work with dynamic text.
#10 napalias
  • 5 posts
Posted 19 March 2007 - 04:27 AM
Thanks
I'm found another way:
onClipEvent (load) {
shuffle = chr(random(26)+65);
and embend
