Help with photoshop
4 replies to this topic
#1 BooBs
  • 4 posts
Posted 16 March 2007 - 10:07 PM
yeah i was looking at this tut and it said to use a pen tool. heres the link http://www.empiredezign.com/version2/portf...als/3dphoto.htm
and its teh 12th step. that is just like one example
heres another example that it says to use the pen tool http://www.yourphotoshopguide.com/index.ph...al&tutid=66
its the part to make a triangle with a pen tool. it says to use a pen tool but idk if i use the Pen Tool or the Freeform Pen Tool. bc  i cant make a triangle like he had with the PEN TOOL. so plz help
(the question might be hard to get my english is not that good)
and one more thing i didnt know under which topic does this go to so i just put it in this topic General
#2 Dance
  • 871 posts
Posted 16 March 2007 - 10:18 PM
I wrote a long weard post that has somethig to do with the pen tool in the thread below.
http://www.pixel2life.com/forums/index.php...9478&hl=pen
Edited by Dance, 16 March 2007 - 10:18 PM.
#3 Scythar
    Honored X Staff
  • 1,888 posts
Posted 17 March 2007 - 07:32 AM
I also made several post to use the pen tool.
#4 BooBs
  • 4 posts
Posted 17 March 2007 - 09:08 AM
can i get a link for it and take a look at it ohhhh and if some one knows about a good tut using a pen tool i wanna c it. I wanna learn how to use it bc it seems that its used a lot.
and also how do u cut out objects from pictures i just go to Quick Mask mode and select a brush and i paint over the object i wanan cut out. but i know there r other ways u can cut out so can u give an advise?
#5 Dance
  • 871 posts
Posted 17 March 2007 - 10:06 PM
Man, there are so many tutorials on this out there, There are more techniques for freelaying images then times the Bush family choked on food. Just search the tutorial index for "extraction" or "free laying" or something like that.
Edited by Dance, 17 March 2007 - 10:07 PM.
