hello i need some help !!!
i am very new to dreamwever and i can not seem to make my webpage apper central on diffrent resiloution monitors. and adjusts the screen size is changed, i tryed using tabels and layers but it dosnt seem to work any advice would be apreciated.
help
Started by NAC, Mar 25 2007 01:38 PM
1 reply to this topic
Posted 25 March 2007 - 01:38 PM
Posted 26 March 2007 - 09:12 AM
I think what you're asking is to center your design. If you're using tables, do you have align=center defined on your main table? If you're using CSS, you want the left and right margins to be defined as auto for your container div. Also, a link to your example would help as well!
