Key problem
5 replies to this topic
#1 Eibbie
  • 5 posts
Posted 26 March 2007 - 05:48 PM
_root.save = true;
//Save Keys
if (Key.isDown(Key.BACKSPACE) && _root.save == true) {
 save.goatoAndStop(2);
 _root.left = false;
 _root.up = false;
 _root.right = false;
 _root.down = false;
 _root.shift = false;
 _root.save = false;
} else if (Key.isDown(Key.BACKSPACE) && _root.save == false) {
 save.gotoAndStop(1);
 _root.right = true;
 _root.left = true;
 _root.up = true;
 _root.down = true;
 _root.shift = true;
When I press backspace, nothing happens.. It was supposed to be on frame 2. Would anyone help me?
#2 gostmn26
  • 12 posts
Posted 26 March 2007 - 08:17 PM
First did you mispell this here in your script
Have you tried putting it below your root timeline as you have before like this?
_root.save.gotoAndStop(2)
Edited by gostmn26, 26 March 2007 - 08:20 PM.
#3 Eibbie
  • 5 posts
Posted 27 March 2007 - 04:23 PM
Woops, I didn't notice that thanks, but still.. It won't appear even I try to put the script inside save MC.
onClipEvent (load) {
	_root.save = true;
onClipEvent (enterFrame) {
	//Save Keys
		_root.save.gotoAndStop(2);
		_root.left = false;
		_root.up = false;
		_root.down = false;
		_root.save = false;
		_root.save.gotoAndStop(1);
		_root.right = true;
		_root.left = true;
		_root.up = true;
		_root.down = true;
		_root.shift = true;
#4 bezz
  • 23 posts
  • Interests:Flash, Snowboarding, Paintball, Learning Guitar
Posted 28 March 2007 - 10:23 AM
what is _root.save? a movie clip or a variable? You set it to false in one section of the code and tell it to got to frame 2 in another part of the code. If it is a movie clip, make sure the instance name of that movieclip is set to 'save'. The instance name box can be located by clicking the movie clip and opening the properties tab.
#5 gostmn26
  • 12 posts
Posted 28 March 2007 - 11:01 AM
Bezz.....you gave me an euphoric moment when i read what you said....lol.....
I sat here and motors clicked and solved a problem for me in another program. DOH.....
Well thanks ;)
YTBG
#6 Eibbie
  • 5 posts
Posted 28 March 2007 - 03:09 PM
Woops, both. I changed a movie clip's instance name to sm. A variable is same, but even after I changed the code and pressed backspace, the movieclip won't show! ._.
 _root.save = true;
 //Save Keys
  _root.sm.gotoAndStop(2);
  _root.left = false;
  _root.up = false;
  _root.down = false;
  _root.save = false;
  _root.sm.gotoAndStop(1);
  _root.right = true;
  _root.left = true;
  _root.up = true;
  _root.down = true;
  _root.shift = true;
  _root.save = true;
