HELP with dreamweaver
1 reply to this topic
#1 kyle9013
  • 14 posts
Posted 02 March 2005 - 01:51 PM
i need help in dreamweaver moving objects anywhere on the page. is there a way i can do that. Thanks Kyle
#2 baku_of_tantalus
  • 36 posts
Posted 24 March 2005 - 01:14 AM
Create a layer and place the object in the layer and move the layer around OR go into LAYOUT view and make a table and place a Cell in the table where ever you want the object then place the object in there. (*NOTE* with the second option, you can't put a cell inside a cell, it must be in an empty space of a tabel) (*NOTE 2* With the first one, it has limited compatibility with different browsers)
