Mysql Help
2 replies to this topic
#1 Vanquish
  • 5 posts
Posted 26 May 2007 - 09:48 PM
im making a search for my sisters site and ive managed to get the citys to populate in an dropdown list but what im trying to do is only show 1 selection per city example
lets say i have 100 members and 50 are from chicago and 10 are from boston and so on how would i get the populated list to only show chicago once and boston once instead of 50 chicago and 10 boston
heres the code im using
<form method="post" action="index.php?id=local">
Select City
<select style="width:10%" name="location">
include("config.php");
$r = mysql_query("select * from users");
while($row = mysql_fetch_assoc($r))
echo "<option value='{$row['location']}'>{$row['location']}</option>";
</select>
<input type="Submit" name="Submit" value="Submit">
</form>
and the search file
$search=$_POST["location"];
$result = mysql_query("SELECT * FROM users WHERE location LIKE '%$search%'");
//grab all the content
while($r=mysql_fetch_array($result))
   //modify these to match your mysql table columns
   $name=$r["username"];
   $locate=$r["location"];
   echo "$name <br> $locate<br /><br />";
Thanks to anyone who can help
#2 rc69
    PHP Master PD
  • 3,827 posts
  • Interests:Web Development
Posted 27 May 2007 - 01:43 AM
$r = mysql_query("SELECT DISTINCT `location` FROM `users`");
while($row = mysql_fetch_assoc($r)){
echo '<option value="'.$row['location'].'">'.$row['location'].'</option>';
Should work, if not, i'm sure i can think of something a little more complicated.
p.s. For demonslay's sake, i do make frequent parse errors :(
Edited by rc69, 27 May 2007 - 01:44 AM.
#3 Vanquish
  • 5 posts
Posted 27 May 2007 - 10:06 AM
That worked perfectly thank you very much!!!
