Okay, so i'm having issues with Nintendo WiFi on my Nintendo DS. This only appears to happen when i'm playing Pokémon Diamond online. I've gone to the 'Hub Manager', and the Router seems to acknowledge the fact that the DS is connected to it.
The DS will connect to Nintendo WiFi successfully, and then a 'Connection Error' message will pop up.
Any help would be appreciated.
Nintendo WiFi issues
Started by Pokeh, May 28 2007 08:10 AM
2 replies to this topic
Posted 28 May 2007 - 08:10 AM
Posted 28 May 2007 - 11:23 AM
We used one of those on our Wii once it wouldn`t connect if our firewall was on so maybe try turning that off and retry.
I don`t use one anymore ours was connected to the main PC and one morning I noticed a chinese name was logged in via the wifi, they changed my IP`s so we had no access at all but it was open to whomever to connect except us.
I went through Nintendo to ask for help, eventually my isp had to completely reset our router and IP, so unsure if this will help you or not but maybe you have someone else connecting on it when you turn it on and if that`s the case you need to look deeper at your connections.
Posted 01 June 2007 - 09:15 AM
