Importing Poser figures into 3D Studio Max?
  • Please log in to reply
5 replies to this topic
#1 Angels
Angels
  • 2 posts
Posted 28 May 2007 - 10:01 PM
Hi all
I'm wondering how can I import a poser scene into 3D studio max 8?
I need to import the actual base figure (it doesn't have to be posable in Max), it's textures and morphs, it's hair figure, and it's pose.
The farthest I've gotten so far is exporting the figure as an OBJ, and importing it into max. It imports just fine, but it doesn't have a texture (or eyeballs), and when I zoom in on it in max, it disappears but renders just fine.
I've tried the GestureMax plugin, but it didn't work.
Thanks if anyone can help!
-Angels
#2 _*Creative Insanity_*
  • Guests
Posted 29 May 2007 - 01:29 AM
You can buy a plug-in from Daz3D that imports all objects from a poser model, even the bones for animation.
#3 Angels
Angels
  • 2 posts
Posted 29 May 2007 - 05:26 AM
Do you know what the plugin is called? They have a lot on their site :dance:
#4 Scythar
Scythar
    Honored X Staff
  • 1,888 posts
Posted 29 May 2007 - 05:58 AM
http://www.daz3d.com.../...646&cat=363
pcharacter2FBX
but theres also plugin for 3dsmax, to import the poser .cr file instead of converting poser --> fbx format.
will look for it.
Body Studio:
http://store.e-front...h_product_24613
Edited by Scythar, 29 May 2007 - 06:03 AM.
#5 _*Creative Insanity_*
  • Guests
Posted 29 May 2007 - 02:03 PM
Angel the Daz stuff is damn good. I bought their plugin for Maya and I have also bought a lot of their Poser packs as well. Excellent stuff. Some is a little pricey, but worth it really when you see the time you save.
#6 Scythar
Scythar
    Honored X Staff
  • 1,888 posts
Posted 29 May 2007 - 02:49 PM
Actually i am a DAZ "platinum club" member, which basicly means my CC is running away the moment i mention there name :lol: .
