str_split not defined?
1 reply to this topic
#1 high6
  • 57 posts
Posted 01 June 2007 - 10:18 PM
Well my friends host(I have a sub) has the latest php but the function http://www.php.net/m...n.str-split.php doesn't work? Is there a reason it wouldn't work or another function like that, that i can use instead?
#2 rc69
    PHP Master PD
  • 3,827 posts
  • Interests:Web Development
Posted 02 June 2007 - 12:10 AM
So you're saying your friend is running php 5? Or just the latest version of php 4? That would make a difference.
But, depending on exactly how you are using it, explode() would be your next best bet.
i.e.
explode('', $string);
// or
explode("\n", $string);
Of course, you could easily make a str_split function using a for loop.
