Audio Player
2 replies to this topic
#1 d2Squared
  • 828 posts
  • Interests:Swimmig<br />Web-design<br />Starcraft
Posted 17 June 2007 - 12:29 PM
Hey, I am looking for some help with the following action script.
Things I need help in changing are:
1. When you switch songs from one song to another it makes that lower volume to higher volume effect, now, I need to stop it. I don't want any special features except playing the song normally from the start.
2. I need to change the colors of the "Songs titles" at the bottom, how do I do that?
3. Also, I need to make that player a bit bigger if possible.
4. When the song is playing, it doesn't show it's name on the bar.
Demo of the player
Here is the actionscript:
stop();
title_txt.autoSize = "left";
timeDisplay_txt.autoSize = "left";
toolTip._visible = false;
var amountLoaded:Number;
var duration:Number;
playlist = new XML();
playlist.ignoreWhite = true;
playlist.onLoad = function(success) {
	if (success) {
		_global.songname = [];
		_global.songband = [];
		_global.songfile = [];
		for (var i = 0; i<playlist.firstChild.childNodes.length; i++) {
		_global.songname[i] = playlist.firstChild.childNodes[i].attributes.name;
		_global.songband[i] = playlist.firstChild.childNodes[i].attributes.band;
		_global.songfile[i] = playlist.firstChild.childNodes[i].attributes.file;
		attachMovie("butTemp","but"+i,i+50);
		eval("but"+i).id=i;
		_root["but"+i]._x = 5;
		_root["but"+i]._y = 40 + (i*15);
		_root["but"+i].but_txt.text = songname[i];
		if (i >= 3){
			_root["but"+i]._x = 160
			_root["but"+i]._y = -5 + (i*15);
		_root["but"+i].onRelease = function(){
			clearInterval(timeInterval);
			_root.timeDisplay_txt.text = "00:00/00:00";
			_root.sound_mc.songStarter(songfile[this.id]);
	_root.sound_mc.songStarter(songfile[song_nr]);
	_root.createEmptyMovieClip("sound_mc", 1);
	_global.song_nr = random(songfile.length);
function timer(sound_obj) {
	time = sound_obj.position/1000;
	min = Math.floor(time/60);
	min = (min<10) ? "0"+min : min;
	sec = Math.floor(time%60);
	sec = (sec<10) ? "0"+sec : sec;
	timeDisplay_txt.text = min+":"+sec+"/"+totalDuration;
function duration (){
	timed = _root.sound_mc.sound_obj.duration/1000;
	mind = Math.floor(timed/60);
	mind = (mind<10) ? "0"+mind : mind;
	secd = Math.floor(timed%60);
	secd = (secd<10) ? "0"+secd : secd;
	totalDuration = mind+":"+secd;
MovieClip.prototype.songStarter = function(file) {
	if (this.sound_obj) {
		this.sound_obj.stop();
		delete this.sound_obj;
	this.sound_obj = new Sound(this);
	this.sound_obj.loadSound(file, true);
	this.sound_obj.setVolume(0);
	this.onEnterFrame = function() {
		if (this.sound_obj.position>0) {
			delete this.onEnterFrame;
			timeInterval = setInterval(timer, 1000, this.sound_obj);
			track = this.sound_obj.id3.songname;
			artist = this.sound_obj.id3.artist;
			this._parent.title_txt.text =artist+" - "+track;
		} else {
			this._parent.title_txt.text = "loading...";
	this.sound_obj.onSoundComplete = function() {
		(song_nr == songfile.length-1) ? _global.song_nr=0 : _global.song_nr++;
	this._parent.volume1.dragger.onPress = function() {
		startDrag(this, true, 0, this._y, this._parent.volBG._width, this._y);
		_root.toolTip._visible = true;
		setInterval(draggableTip,100);
		function draggableTip(){
			_root.toolTip._x = _root._xmouse;
			var p = (this._x/this._parent.volBG._width)*100;
			this._parent._parent.sound_mc.sound_obj.setVolume(p);
	this._parent.volume1.dragger.onRelease = function() {
		stopDrag();
	this._parent.volume1.dragger.onReleaseOutside = function() {
		_root.toolTip._visible = false;
		stopDrag();
function soundStatus(){
	var amountLoaded = _root.sound_mc.sound_obj.getBytesLoaded() / _root.sound_mc.sound_obj.getBytesTotal();
	_root.loader.loadBar._width = amountLoaded * 260;
	duration = _root.sound_mc.sound_obj.duration;
	position = _root.sound_mc.sound_obj.position;
	_root.playHead._x = position / duration * 272 + 5;
btn_play.onRelease = function() {
	this._parent.sound_mc.songStarter(songfile[song_nr]);
btn_stop.onRelease = function() {
	this._parent.sound_mc.sound_obj.stop();
btn_fw.onRelease = function() {
btn_rev.onRelease = function() {
	(song_nr == 0) ? _global.song_nr=songfile.length-1 : _global.song_nr--;
playlist.load("playlist.xml");
setInterval(duration,100);
setInterval(soundStatus,100);
Thanks in advance :)
Edited by d2Squared, 17 June 2007 - 12:30 PM.
#2 d2Squared
  • 828 posts
Posted 18 June 2007 - 04:17 AM
Guys...please, I am in an urgent need for that :)
#3 Pax
  • 911 posts
Posted 18 June 2007 - 08:57 AM
I commented out a line that set the volume to 0, which should fix your volume problem. The rest I believe should just be modifying the assets for your mp3 player. Making windows bigger, and changing font colour should be done from the Flash IDE. I don't think anything is done through code. Hope that helps.
stop();
    if (success) {
        eval("but"+i).id=i;
        if (i >= 3){
  //  this.sound_obj.setVolume(0);  // This line should remove the cross fade thing
        } else {
        stopDrag();
        stopDrag();
