ok well i installed, Windows Vista Skins and all that stuff on my pc and i uninstalled it but its still there the skin, like when you start up your pc and shows to what account you want to log in and the cursors and the buttens but i want my original Windows Xp home back because the vista lags too much, could someone explain what i should do please?
Pc Skin help
Started by CrazedLlama, Jun 17 2007 02:52 PM
3 replies to this topic
Posted 17 June 2007 - 02:52 PM
Posted 17 June 2007 - 05:45 PM
Did you use a program to install them? if so reinstall the program set it back to your default then remove the program.
Posted 17 June 2007 - 10:32 PM
A: Get a new computer and keep vista.
B: Don't get a new computer and reinstall XP.
C: Listen to donna.
D: All of the above.
C: Listen to donna.
Posted 18 June 2007 - 07:19 AM
rofl...I think RC just about covered it.
I installed a World of Warcraft theme on my PC once and even after uninstalling it many settings were hosed and I just had to format/reload it.
