ei guys, can someone help me to disable the background of my webpage so anyone could'nt save it?
many thanks guys
background help
Started by Totie, Jun 20 2007 03:58 AM
4 replies to this topic
Posted 20 June 2007 - 03:58 AM
Posted 20 June 2007 - 04:45 AM
Hmm.. Im not too sure how to do that, but if you are cheap and cheerfull like me and really lazy like me too.. Just add a "No Right Click" Script
Found that on DynamicDrive.com
People may still use the "View Source" button, but at least you have countered it a little
Also, im sure there is a script that jumbles your code, so like.. when you click "View Page Source" Its just a load of jibberish, anyone back me up on that?
<script language=JavaScript>
//Disable right click script III- By Renigade (renigade@mediaone.net)
//For full source code, visit [url="http://www.dynamicdrive.com"]http://www.dynamicdrive.com[/url]
var message="";
function clickIE() {if (document.all) {(message);return false;}}
function clickNS(e) {if
(document.layers||(document.getElementById&&!document.all)) {
if (e.which==2||e.which==3) {(message);return false;}}}
if (document.layers)
{document.captureEvents(Event.MOUSEDOWN);document.onmousedown=clickNS;}
else{document.onmouseup=clickNS;document.oncontextmenu=clickIE;}
document.oncontextmenu=new Function("return false")
</script>
Edited by S0LDIER., 20 June 2007 - 04:45 AM.
Posted 20 June 2007 - 06:18 AM
Yeah, I'm not for certain but like Soldier said I'm sure you can find some type of script to mask where it's coming from...maybe.
For instance, the company I work for uses an ASP thumbnail generator so instead of listing the picture's name each image points to exactly the same location and can't be stolen...kinda cool actually.
Posted 20 June 2007 - 02:15 PM
No, you can't.
1. Disable JS... takes 2 seconds.
2. Print Screen... takes less than 2 seconds.
Besides, if it is a background image, you can't right click and save anyways.
Posted 20 June 2007 - 02:23 PM
ROFL rc, you're my hero.
