MovieClip buttons (active link problem)
1 reply to this topic
#1 Pedro Silva
  • 4 posts
Posted 11 July 2007 - 10:27 AM
Hi guys, I have one menu embebed in a mc, with transparent button and with animation tint on rollover and rollout, but I wan't to force the letter staying black on release the transparent button, well but my real problem is who to change again color when the user click another link.
Thanks
#2 Pax
  • 911 posts
Posted 11 July 2007 - 09:35 PM
Create an array and add each button to the array when the buttons load. Give each button a selected property. Then add the follwong code on each button event you have (onRollOver, onRollOut, etc) before any other code. This code will prevent anything else from being executed if the button is selected.
if(mySelectedVariable == true){
return; // halts execution of the code
This code doesn't use shorthand so it'll be easier for you to understand. When you click a button, you want to loop through the array youve stored all your buttons in, and set their selected variable to false. After that, set the selected variable to true on the clicked button.
That should do it.
