Problems with masks
2 replies to this topic
#1 Flanders
  • 53 posts
  • Gender:Female
  • Interests:web design, graphic design, photography, philosophy, politics, myst, the sims, maple story
Posted 11 July 2007 - 03:32 PM
I want to mask a gradient over an object to give it a shine effect. I've gone through every tutorial on here, and the conclusion I've come to is that they're written if you want to mask a flash-created shape. I have an image that importing that I'd like to mask though, and it's not quite as convenient as a rectangle, so is there a way I can apply a mask without having to make a shape of the object?
#2 Ben
    P2L Jedi Master
  • Publishing Betazoids
  • 1,366 posts
Posted 11 July 2007 - 08:34 PM
Nope :( Unless it's a transparent png (actually, it still might not work)
Edited by Ben, 11 July 2007 - 08:34 PM.
#3 Pax
  • 911 posts
Posted 11 July 2007 - 09:51 PM
Now, I'm not entirely sure if this will work, however, if you try using the bitmapData API, you may be able to create an image of only solid pixels (ie, removing any transparent pixels) to make a shape of the object. Copy that shape into a movie clip and use that clip as the mask.
Like I said...no idea if it'll work (I've never tried it) but it's the best thing I can think of right now.
Good Luck.
