Preloader problem
11 replies to this topic
#1 Flanders
  • 53 posts
  • Gender:Female
  • Interests:web design, graphic design, photography, philosophy, politics, myst, the sims, maple story
Posted 23 July 2007 - 07:41 PM
All right, I've been trying to figure this out for awhile now...I decided I finally need to ask for help...
I created a preloader for our website, http://www.digitalzone1.com, but for some reason it only shows after it's loaded 75%. I can't really figure out why this is, other than the fact that I've never had much luck with preloaders.
If anyone could make a suggestion, I'd really appreciate it. The site is up for an award come September, and I want it in the best shape possible for when the voting starts in August. ^^ That, and I can't stand that it doesn't work right.
Here's the ActionScript I'm using:
bytes_loaded = Math.round(this.getBytesLoaded());
bytes_total = Math.round(this.getBytesTotal());
getPercent = bytes_loaded/bytes_total;
this.loadBar._width = getPercent*100;
this.loadText = Math.round(getPercent*100)+"%";
if (bytes_loaded == bytes_total) {
	this.gotoAndPlay(3);
Thank you! :biggrin:
#2 lysol
  • 140 posts
Posted 23 July 2007 - 09:36 PM
could you PM me your .FLA file?
#3 Pax
  • 911 posts
Posted 23 July 2007 - 09:47 PM
You should use an initial preloader swf that contains nother other than the preloaders graphics and the background, then use that file and the MovieClipLoader class to load up your main swf. That way the preloader will show up as soon as all of its assets have loaded, but it won't try and load all the classes and stuff for the swf on the first frame.
I also suggest only using a single frame preloader. Just use an onEnterFrame = function(){} And put your code in that on the first frame rather than a two frame loader. Ive always had problems with those.
If you use the first option, it'll kill any code that uses _root, but you shouldn't be using that much anyways.
#4 lysol
  • 140 posts
Posted 23 July 2007 - 10:15 PM
try this. works for me everytime.
onClipEvent (load) {
 total = _root.getBytesTotal();
  onClipEvent (enterFrame) {
 loaded = _root.getBytesLoaded();
 percent = int(loaded/total*100);
 perc = ""+percent+"%";
 gotoAndStop(percent);
 if (loaded == total) {
  _root.gotoAndPlay(2);
Edited by Lopezt, 23 July 2007 - 10:15 PM.
#5 Pax
  • 911 posts
Posted 24 July 2007 - 07:35 AM
I wouldn't recommend using _root, onClipEvent() or on() in your code. It's bad practice.
#6 lysol
  • 140 posts
Posted 24 July 2007 - 08:48 AM
^sure. What would you recommend?
#7 Pax
  • 911 posts
Posted 24 July 2007 - 09:03 AM
Use
this.onEnterFrame = function(){
//some code here
And reference movie clips using _parent's and the instance name of the target clip. Best practice is to put all your code on one frame, rather than putting it on instances of movie clips on the stage.
#8 lysol
  • 140 posts
Posted 24 July 2007 - 12:22 PM
Interesting...thanks for the tip.
#9 Flanders
  • 53 posts
  • Gender:Female
Posted 24 July 2007 - 12:44 PM
So what I should do is isolate the preloader in its' own .swf and import that into the main .swf? I'm sorry if I'm not grasping this; again, I'm pretty new to Flash.
#10 Pax
  • 911 posts
Posted 24 July 2007 - 03:44 PM
Got the isolation part right, but the other way around.
Say you have a file called preloader.fla and preloader.swf. It is the preloader.swf that you would embed into your html page. This preloader.swf would load your main site swf into a movieclip within preloader.swf.
#11 Flanders
  • 53 posts
  • Gender:Female
Posted 25 July 2007 - 02:32 PM
Okay, I've created two separate files...how would I go about having the preloader actually the call the main site? I'm having trouble figuring out how to sync up the two elements...
#12 Pax
  • 911 posts
Posted 25 July 2007 - 03:06 PM
Look for info on the moviecliploader class. Use that with your progress bar to load the main site.
