Help in Flash
1 reply to this topic
#1 patellio
  • 70 posts
Posted 13 March 2005 - 07:13 PM
I was trying to create a preloader with this background:
http://img.photobucket.com/albums/v516/pat...ortfolio_02.png
when i kept having sum problem...I wanted it to turn out sumthing like this:
http://img.photobuck...io/untitled.bmp
Could somebody please make one for me with that first pixture as the backround and with the same colours for the box and everything as in the second picture? Thx alot for all of your help and hard work in advance.
EDIT*if you can, please make it a box loader with text on top of the box saying "LOADING" and then the percent loaded. The text and box frame should be in Black and the bar colour shoould be a dark gray if you can do so....Thx again*
-patellio
Edited by patellio, 13 March 2005 - 07:15 PM.
#2 Faken
    Pimpmaster G
  • Admin
  • 5,918 posts
Posted 17 March 2005 - 01:26 AM
-patellio
You can just go to www.flashkit.com and download a ready made preloader. All you have to do is add your image to a lower layer and you're all set B) If you need it done, PM me and I will do it for a minimal fee. (Yes I charge for work I do... sorry.)
Faken
