I am sure that I have missed something here. I just finished the tut for the MP3 III w//XML by funkysoul (awesome btw!) and overall it works great but I can't seem to get the song title to display from the playlist - it just says "undefined".
I'm guessing that it has something to do with this line "_root.sound_mc.songStarter(songfile[this.id]);"
Note that I've opted out of the scolling text - I prefer the non-scolling from part I (or was that II?...)
Here's my AS - hopefully I haven't mangled it too much
Any help would be GREATLY appreciated!
Thanks...Will
stop();
playlist = new XML();
playlist.ignoreWhite = true;
playlist.onLoad = function(success) {
if (success) {
_global.songname = [];
_global.songband = [];
_global.songfile = [];
for (var i = 0; i<playlist.firstChild.childNodes.length; i++) {
_global.songname[i] = playlist.firstChild.childNodes[i].attributes.name;
_global.songband[i] = playlist.firstChild.childNodes[i].attributes.band;
_global.songfile[i] = playlist.firstChild.childNodes[i].attributes.file;
// trace(songname[i]+" "+songfile[i]+" "+songband[i]);
attachMovie("butTemp","but"+i,i+50);
eval("but"+i).id=i;
_root["but"+i]._x = 20;
_root["but"+i]._y = 100 + (i*15);
_root["but"+i].but_txt.text = songname[i];
if (i >= 8){
_root["but"+i]._x = 160
_root["but"+i]._y = -5 + (i*15);
_root["but"+i].onRelease = function(){
_root.createEmptyMovieClip("sound_mc", 1);
_global.song_nr = random(songfile.length);
_root.sound_mc.songStarter(songfile[song_nr], songname[song_nr], songband[song_nr]);
function timer(sound_obj) {
time = sound_obj.position/1000;
min = Math.floor(time/60);
min = (min<10) ? "0"+min : min;
sec = Math.floor(time%60);
sec = (sec<10) ? "0"+sec : sec;
timeDisplay_txt.text = min+":"+sec;
MovieClip.prototype.songStarter = function(file, name, band) {
if (this.sound_obj) {
this.sound_obj.stop();
delete this.sound_obj;
this.sound_obj = new Sound(this);
this.sound_obj.loadSound(file, true);
this.onEnterFrame = function() {
if (this.sound_obj.position>0) {
delete this.onEnterFrame;
this._parent.display_txt.text = name;
timeInterval = setInterval(timer, 1000, this.sound_obj);
} else {
this._parent.display_txt.text = "loading...";
this.sound_obj.onSoundComplete = function() {
clearInterval(timeInterval);
this._parent.timeDisplay_txt.text = "00:00";
(song_nr == songfile.length-1) ? _global.song_nr=0 : _global.song_nr++;
this._parent.volume1.dragger.onPress = function() {
startDrag(this, true, 0, this._y, this._parent.volBG._width, this._y);
var p = (this._x/this._parent.volBG._width)*100;
this._parent._parent.sound_mc.sound_obj.setVolume(p);
this._parent.volume1.dragger.onRelease = function() {
stopDrag();
this._parent.volume1.dragger.onReleaseOutside = function() {
stopDrag();
btn_play.onRelease = function() {
if (pause == true){ // no comment....
this._parent.sound_mc.sound_obj.start(posiP) // start sound from the previously saved position
else {
_root.timeDisplay_txt.text = "00:00/00:00";
this._parent.sound_mc.songStarter(songfile[song_nr]);
btn_pause.onRelease = function() { //pause button function
this._parent.sound_mc.sound_obj.stop(); //stop the current sound
posiP = _root.sound_mc.sound_obj.position / 1000; // save the current position in a new variable and divide by 1000 (ms -> sec)
pause = true;//set the variable pause to true
btn_stop.onRelease = function() {
btn_fw.onRelease = function() {
_root.sound_mc.songStarter(songfile[song_nr], songname[song_nr]);
btn_rev.onRelease = function() {
(song_nr == 0) ? _global.song_nr=songfile.length-1 : _global.song_nr--;
playlist.load("playlist.xml");
