iPhone flash scroll :)
  • This topic is locked This topic is locked
11 replies to this topic
#1 curthard89
curthard89
  • 226 posts
Posted 17 August 2007 - 05:42 AM
Yo guys, this is just some class ive been working on.
have a play....any comments would be appreciated.
works better in its native moviesize, but sum browsers make swf go full screen.
alot smoother in native size
Edited by curthard89, 17 August 2007 - 07:13 AM.
#2 Mezzo
Mezzo
  • 102 posts
Posted 17 August 2007 - 08:56 AM
Very nice, the motions smooth. Now...who is Abbi Someone and why are they in every letter :)
#3 curthard89
curthard89
  • 226 posts
Posted 17 August 2007 - 09:48 AM
cheers Mezzo, not bad for 3 hours work.....
any1 want the class file? commented it n all lol.
erm...just shout in here if u do
Edited by curthard89, 17 August 2007 - 09:48 AM.
#4 tomos
tomos
  • 58 posts
Posted 17 August 2007 - 11:44 AM
V nice
#5 dcpweb
dcpweb
  • 60 posts
Posted 19 August 2007 - 07:50 PM
Good start, needs a lot of work.
p shah - www.dcpweb.co.uk
Edited by dcpweb, 19 August 2007 - 07:51 PM.
#6 curthard89
curthard89
  • 226 posts
Posted 20 August 2007 - 02:10 AM
does it? works fine for me
#7 Pax
Pax
  • 911 posts
Posted 20 August 2007 - 08:17 AM
Yea, its got a good chunk of bugs in it. Common problems with dragging things in Flash. Seems some of your math might be off too. If you throw the menu down, the entire thing disappears then slides back up. Doesn't look right. Also, if you click, drag left and release, there is no listener (or its not doing anything) for the onReleaseOutside event. This just makes the drag stuck to the cursor.
#8 curthard89
curthard89
  • 226 posts
Posted 20 August 2007 - 09:40 AM
ah drag out, ok (Y), yer i know what u mean about it disapearing then sliding bk, just runs the tweenback function on the other tweens onMotionFinished
#9 Pax
Pax
  • 911 posts
Posted 20 August 2007 - 09:47 AM
Yeah...you should investigate other methods instead of the Tween class. Its not the best out there. Check out FuseKit and the ZigoEngine @ www.mosessupposes.com. Probably the best way to handle any sort of animation in Flash.
#10 curthard89
curthard89
  • 226 posts
Posted 20 August 2007 - 10:34 AM
well it was just an experiment to see if it could be done with built in tween classes. Thought i had a pretty good attempt
#11 curthard89
curthard89
  • 226 posts
Posted 21 August 2007 - 09:55 AM
right ok, few bugs fixed, such as drag out and the moving of screen to far bit. Tried to get it as real as the iPhone bounce.
further comments would be appreciated.
Im sure there are still a few bugs in it.
#12 DeathWish^!
DeathWish^!
  • 501 posts
  • Interests:Photoshop :)
Posted 21 August 2007 - 01:35 PM
really smooth good work
