Ajax Submit Problem [SOLVED]
5 replies to this topic
#1 Braunson
  • 237 posts
Posted 17 August 2007 - 09:39 PM
Okay heres my main page for my 'edit category' for my gallery.
if(isset($_POST["save_category"])) {
	// this is our variables being submitted
	$title = htmlspecialchars($_POST["title"]);
	$description = htmlspecialchars($_POST["description"]);
	$date_added = date("F j, Y");
	$id = $_POST["id"];
	$etable = "Edited category from the Gallery";
	$result = mysql_query("UPDATE `admin_details` SET lastedit = '$etable' WHERE username='$username'");
	 $result = "UPDATE `gallery_categorys` SET title = '$title', description = '$description' WHERE id = '$id'";
		mysql_query($result)or die(mysql_error());
	// success, settings updated, now to redirect or echo something.
	echo "<meta http-equiv=\"refresh\" content=\"3 url=$domain/admin/index.php\">";
	echo "	<h1>Category Successfully Edited</h1>
		<p>Your gallery category have been successfully edited, and you are now being redirected back to the administrative home.</p>
} else {
			<a name="editcategory"></a>
			<h1>Edit Category</h1>
			<p>Feel free to edit a gallery category. You can do so below using the form below.</p>
<table width="100%" border="0" cellpadding="0" cellspacing="3" align="left">
<!--- settings start -->
	<tr>
		<td width="45%"><strong>» Select Category</strong></td>
		<td width="50%">
		<form>
			<select name="photos" onchange="showGalleryCategorys(this.value)" style="margin: 0px; width: 95%; padding: 3px; border: 1px solid #e6e6e6;" />
			<option value="">---- Select an Category ----</option>
		  $query = mysql_query("SELECT * FROM `gallery_categorys` ORDER BY position ASC");
		ifempty($query);
		while($r = mysql_fetch_array($query)){
			$id = $r["id"];
			$title = $r["title"];
echo "					<option value =\"$id\">$title</option>
			</select>
			</form></p>
		</td>
	</tr>
<!--- settings end -->
</table>
	<form name="pform" method="post" action="<?=$domain;?>/admin/index.php?go=pages/gallery&do=edit_category">
			<div id="txtHint"></div>
	</form>
</table></p>
Now I have it load forms to edit in txtHint area through edit_category_2 using javascript & the dropdown.
But when I go to submit it and save it, it dosn't submit, it dosnt do anything.
Any ideas people?
Edited by Braunson, 07 September 2007 - 07:59 AM.
#2 Braunson
  • 237 posts
Posted 17 August 2007 - 09:42 PM
Edit, I found out when it displays the form to edit. the html is messed up. the content inside div id="txtHint" is moved out of the table... like so below..
<div id="txtHint">
		<strong>» Title</strong>
		<input name="title" value="Indoor Pool" style="border: 1px solid rgb(230, 230, 230); margin: 0px; padding: 3px; width: 95%;" type="text">
		<input name="id" value="3" type="hidden">
		<strong><br>» Description</strong>
		<textarea name="description" style="border: 1px solid rgb(230, 230, 230); margin: 0px; padding: 3px; width: 95%;">This is the indoor pool area</textarea>
		<input name="save_category" value="Finish Editing Category »" style="border: 1px solid rgb(230, 230, 230); margin: 5px 0px; padding: 4px; width: 50%; font-weight: bold; text-transform: uppercase;" type="submit">
</div>
	<table align="left" border="0" cellpadding="0" cellspacing="3" width="100%">
	<form name="pform" method="post" action="http://site.com/admin/index.php?go=pages/gallery&amp;do=edit_category"></form>
</table>
Why would it be doing this :P
#3 Demonslay
  • 970 posts
Posted 18 August 2007 - 07:52 AM
Is it doing that when inserting with JavaScript?
Make sure you are using the innerHTML property if that is how you are inserting it.
#4 Braunson
  • 237 posts
Posted 19 August 2007 - 05:43 PM
Here's how im using it. I didn't create the code.
function showGalleryCategorys(str)
xmlHttp=GetXmlHttpObject()
if (xmlHttp==null)
 alert ("Browser does not support HTTP Request")
 return
var url="./pages/gallery/edit_category_2.php"
url=url+"?q="+str
url=url+"&sid="+Math.random()
xmlHttp.onreadystatechange=stateChanged
xmlHttp.open("GET",url,true)
xmlHttp.send(null)
function stateChanged()
if (xmlHttp.readyState==4 || xmlHttp.readyState=="complete")
 document.getElementById("txtHint").innerHTML=xmlHttp.responseText
function GetXmlHttpObject()
var xmlHttp=null;
try
 // Firefox, Opera 8.0+, Safari
 xmlHttp=new XMLHttpRequest();
catch (e)
 //Internet Explorer
 try
  xmlHttp=new ActiveXObject("Msxml2.XMLHTTP");
 catch (e)
  xmlHttp=new ActiveXObject("Microsoft.XMLHTTP");
return xmlHttp;
Edited by Braunson, 19 August 2007 - 05:44 PM.
#5 .CJ
  • 114 posts
Posted 20 August 2007 - 07:27 AM
Have you considered using Prototype? It makes Ajax that so much more easier... for example, to use it for form submission, you'd do:
new Ajax.Updater('div', 'file.php', {parameters: Form.serialize()});
Then you would add some XHTML like so:
<div id="div"></div>
And the requested data will show up in the DIV.
More information at http://www.prototypejs.org.
#6 Braunson
  • 237 posts
Posted 06 September 2007 - 04:35 PM
No thanks, I've thought of that. I'm trying to keep this script under a certain size. Anybody else know what's wrong with this code :o
