Problem with using if statement
7 replies to this topic
#1 bfva
  • 42 posts
Posted 28 August 2007 - 12:00 PM
I've been writing this code and just can't seem to get it working.
What i'm trying to do is when the url contains a certain, then the corresponding link is highlighted.
EG
If the link is www.mysite.com/h/home/index.php
The link Home is highlighted.
Here is my code
$uri = $_SERVER['REQUEST_URI'];
if ($uri == 'home'){
echo"<ul>";
echo "<li id=\"current\"><a href=\"mysite.com\">Highlight</a></li>";
echo "<li><a href=\"mysite.com\">Highlight</a></li>";
echo "</ul>";
elseif ($uri == 'home2'){
echo"<ul>";
echo "</ul>";
Thanks For Your Help
Edited by bfva, 28 August 2007 - 01:40 PM.
#2 Matt L
  • 272 posts
Posted 28 August 2007 - 12:15 PM
You need to use elseif from the second if, and else on the last one. Otherwise it'll want an else statment for all of the if's.
#3 bfva
  • 42 posts
Posted 28 August 2007 - 12:32 PM
I tried that but it doesn't work. The menu loads but the same one loads even if the other word is present in the uri.
I have updated my code to show you what i did.
Thanks for your help
#4 Mr. Matt
    Moderator
  • 1,945 posts
  • Gender:Not Telling
Posted 28 August 2007 - 01:00 PM
Right well this is simple. On your inside your if condition you are setting $uri = 'home2'. You need to check if it is equal to:
$foo = 'bar'; // $foo is being set to 'bar'
$foo == 'bar'; // Checks to see if $foo equals 'bar'
So you need to change the single '=' to '==', as currently you are setting $uri to home, which will always come out as true.
Matt
Edited by Mr. Matt, 28 August 2007 - 01:02 PM.
#5 bfva
  • 42 posts
Posted 28 August 2007 - 01:41 PM
Matt
I tried it but it still doesn't work, nothing loads.
#6 dEcade
  • 1,850 posts
  • Interests:Guitar, Programming, Storm Chasing, Games (Designing and playing), Hockey, Photography
Posted 28 August 2007 - 04:37 PM
Hi,
say your page is http://example.com/test.php the what your codes uri would be is /test.php. But if it was in more files like http://example.com/t...sting/index.php it would be /test/testing/index.php. So try this:
if ($uri == '/h/home/index.php'){
echo"<ul>";
echo "</ul>";
elseif ($uri == '/h/home2/index.php'){
echo"<ul>";
echo "</ul>";
Edited by dEcade, 28 August 2007 - 04:56 PM.
#7 Marxx
  • 116 posts
Posted 29 August 2007 - 03:43 AM
I have this same problem earlier and find solution..
lets say that you have 2 urls:
http://www.mysite.net/home1/
http://www.mysite.net/home2/
In here, it doesn't matter what file you're showing in those folders. Only folder name matters..
$origurl = $_SERVER['REQUEST_URI'];
if(eregi('.',$origurl)){
$break = explode('/',$origurl);
array_pop($break);
$origurl = implode('/',$break);
$url_array = explode('/', $origurl);
$theurl = $url_array[1];
if($theurl == "home1") {
	  print("This is home1 folder");
} elseif($theurl == "home2") {
	  print("This is home2 folder");
Thanks for curthard89 for guiding me out! :rolleyes:
And hope this help you bfva...
#8 bfva
  • 42 posts
Posted 29 August 2007 - 06:20 AM
array_pop($break);
Thanks mate, that worked perfectly. Thanks everyone for your help.
