Need ImageReady CS2 Help
1 reply to this topic
#1 Jas0n
  • 1 posts
Posted 29 August 2007 - 04:52 PM
Heya,
Ok.. I'm trying to do an animation that needs to run at two different speeds. The first speed has to be 0.1 seconds between each frame for my rain effect and the second speed has to be 0 seconds between each frame for my blurred text effect. So basically, I want to put an animation on top of an animation.. Is this possible? If so, how do I do it?
Thanks for any help :huh:
Edited by Jas0n, 29 August 2007 - 04:55 PM.
#2 Scythar
    Honored X Staff
  • 1,888 posts
Posted 30 August 2007 - 08:11 AM
nope,
not in imageready,
you'll need them to make both of the seperately and then composite them together in another program.
Remember, IR is not an animationprogram, it just has basic anim features, concentrated on webdesign.
