Nav Problems (FIXED)
4 replies to this topic
#1 Lastcrime
    Impatient Jedi that likes to eat cereal
  • 649 posts
  • Interests:Soccer, Snowboarding, Hockey, B-ball, Skateboarding, Computers!
Posted 04 September 2007 - 02:57 PM
i had to add position:absolute to my nav so that i could position it correctly, but now when i go to veiw it on my monitor thats larger then the one i made it on it goes well outside the container, im not sure how to fix this without taking out position:absolute; ?? any ideas ??
Edited by Lastcrime, 04 September 2007 - 05:55 PM.
#2 .CJ
  • 114 posts
Posted 04 September 2007 - 03:31 PM
#blah {
	position: absolute;
	top: 20px;
	left: 30px;
Have you added TOP and LEFT attributes? If not, give it a go, otherwise, post your code.
#3 Av-
    I Feel Left Out
  • 1,971 posts
Posted 04 September 2007 - 04:37 PM
Give your containing div a relative position so it will position relative to it's container rather than the body.
div.container{
position:relative;
If that doesn't fix it, it'll help if you show us an example so we can see what you're heading for.
#4 Lastcrime
  • 649 posts
Posted 04 September 2007 - 04:45 PM
o yah i think position:relative might work and yes .cj i do have top left thats just for positioning though it still moves as the browser gets bigger and smaller , but ill try position:relative; and let you know.
#5 Lastcrime
  • 649 posts
Posted 04 September 2007 - 05:54 PM
Yeah position:relative; worked thanks.
