Won't delete! - Still need HELP
12 replies to this topic
#1 Dat
  • 55 posts
Posted 13 September 2007 - 08:49 PM
This code won't delete my entry!!! ARG and when I add: header("Refresh: edit.php"); after echo "The entry has been deleted"; it says an error: Warning: Cannot modify header information - headers already sent by (output started at /**/delete.php:22) in /**/delete.php on line 23
Here is the code:
//Connecting to the MySQL database
Connect...
//Naming some variables here.
$id = $_GET['id'];
if($_POST['deny']) {
//We shall not delete the entry, my lord.
$path = "http://admin.romanceanime.com/edit.php";
header("Location: $path");
exit;
} elseif($_POST['confirm']) {
//We shall proceed to delete!
//The MySQl query. Deletes an entry from the database.
$query = "DELETE FROM anime_reviews WHERE ID = '$id'";
//Execute the query.
$result = mysql_query($query) or die(mysql_error());
// header("Refresh: edit.php");
} else {
<table align="center">
<form action="delete.php" method="post">
<tr><td>Do you really want to delete this entry?</td></tr>
<tr><td><input type="hidden" name="id" value="<?php echo "$id"; ?>" /><input type="submit" name="confirm" value="Yes" /><input type="submit" name="deny" value="No" /></td></tr>
</form>
</table>
I know I'm making these nooby topic's but this forum has improved my skills greatly thanks.
Edited by Dat, 15 September 2007 - 12:27 PM.
#2 Mr. Matt
    Moderator
  • 1,945 posts
  • Gender:Not Telling
Posted 13 September 2007 - 09:13 PM
A header modification can only be done in PHP before any content has been sent to the browser. In your case you have echo'd somthing to the browser before trying to do a header redirect.
Other options to fix what you are trying to do is do a javascript redirect which you can set to do after x seconds. Or you can redirect to a page to show your message and then redirect onto the page you want to go on to, a bit like what IPB does ( i think ). So e.g.:
When the item has been deleted you don't echo out but do a redirect like this:
header( 'Location: /show_message.php?message=1&redirect=edit.php' ); exit;
Then on your show_message.php page you do a simple check to see which message id has been sent, then show a message according to that ID, then you redirect off to the redirect page you sent across.
This is just basic, and has a few security flaws, but in a private admin area if its protected ok then it should be fine.
Matt
#3 Dat
  • 55 posts
Posted 13 September 2007 - 10:52 PM
Alright setting aside the redirect thing which I think I can solve later. Why isn't it deleting!?
#4 nitr0x
  • 201 posts
Posted 14 September 2007 - 06:43 AM
	 //Connect...
	 $id = $_GET['id'];
	 if( !$id ){
		  die("ID needs to be set.");
	 if( $_POST['deny'] ) {
		  print '<meta http-equiv="Refresh" content="0; URL='. $path .'" />';
	 }elseif( $_POST['confirm'] ) {
		  mysql_query("DELETE FROM `anime_reviews` WHERE `id` = ".$id)or die( mysql_error() );
		  print '<meta http-equiv="Refresh" content="0; URL=edit.php" />The entry has been deleted.';
	 }else{
	 </td>
	 </tr>
	 </form>
	 </table>
Try that, changes:
1. Took out the header location changed it with meta refresh.
2. Add ID security, is it set?
3. Query changed to
Edited by nitr0x, 14 September 2007 - 06:44 AM.
#5 Mr. Matt
    Moderator
  • 1,945 posts
Posted 14 September 2007 - 07:03 AM
The reason why it wouldn't delete as it got to a php error which means the whole script would not run, in turn not deleteing the image, changing the redirect and getting that to work fine may get it working, but like nitr0x has done, you may get an error with your query. So fix the header redirect first because for now that is your main problem.
Matt
#6 Dat
  • 55 posts
Posted 14 September 2007 - 09:15 AM
How do I set the id?
#7 rc69
    PHP Master PD
  • 3,827 posts
  • Interests:Web Development
Posted 14 September 2007 - 02:54 PM
Matt
Wrong, headers() cause non-fatal runtime errors, meaning, the error will show up at the point the script err's. Everything upto that point and typically beyond will be executed.
Parse errors however, are fatal errors and would do as you described (not allow the script to run).
	 $id = $_GET['id'];
Now i'm confused. You're already setting the id, do you mean how to you pass the id to the script?
http://php.net/manual/en/reserved.variable...d.variables.get
#8 Dat
  • 55 posts
Posted 14 September 2007 - 06:57 PM
Matt
	 $id = $_GET['id'];
Before alter the code(before posting this thread) it printed: success but it never did delete it.
After altering the code it still doesn't work but now it says ID needs to be set because of this:
if( !$id ){
#9 Demonslay
  • 970 posts
Posted 14 September 2007 - 09:29 PM
Lol, simple problem guys.
Your form is using the POST method, thus, your variable will be available not in the $_GET superglobal array, but in $_POST.
$id = (int)$_POST['id'];
#10 Dat
  • 55 posts
Posted 14 September 2007 - 10:03 PM
Still not working:
//Connect to database
if( !$id ){
}else{
</td>
</tr>
</form>
</table>
#11 rc69
    PHP Master PD
  • 3,827 posts
Posted 15 September 2007 - 12:30 PM
Lol, demonslay, you want a simple problem eh? Wheres the id coming from now?
if( !$id ){
}else{
	</td>
	</tr>
	</form>
	</table>
$id = (int)($_GET['id'] ? $_GET['id'] : $_POST['id']);
p.s. Dat, please format that code a bit, it's impossible to read...
Edited by rc69, 15 September 2007 - 12:31 PM.
#12 Dat
  • 55 posts
Posted 15 September 2007 - 09:48 PM
if( !$id ){
}else{
	</td>
	</tr>
	</form>
	</table>
Thanks,
So what was the error? Why did this work?
BTW: Can you refer me to a good php editor; I currently use Coda from Panic. Also, I use a Mac.
#13 rc69
    PHP Master PD
  • 3,827 posts
Posted 15 September 2007 - 10:23 PM
Notepad's a good editor. Personally though, i use dreamweaver... auto-tab/color coding helps a lot!
For the fix though, ref: http://php.net/opera...rison#id2539511
Edited by rc69, 15 September 2007 - 10:23 PM.
