I'm not sure what to do, and I've looked all over the place. If anyone has encountered this before and can help me, I would be very appreciated.
USB problem on my computer
Started by Nick, Sep 14 2007 06:33 PM
10 replies to this topic
Posted 14 September 2007 - 06:33 PM
My computer came with vista, and I just got tired of that, so I decided to put XP on it instead. My computer is a HP dv9208nr, and when I initially installed XP, absolutely nothing worked, no drivers or anything. So I went to the HP website and downloaded all of the drivers I needed. Now everything works except there is a small problem with USB. Transferring files to/from ipod or any other usb device is incredibly slow. When I plug in a USB device, I get this error message...
untitled.PNG 15.51K
75 downloads
#2 _*Creative Insanity_*
Posted 14 September 2007 - 09:33 PM
Did you install Service Pack 2?
If not go to MS and download and install SP2 as that has the stuff you need for USB 2.
Posted 14 September 2007 - 09:41 PM
Yes, I was hoping that would fix the problem, but it didn't. Also, after SP2 installed I went to device manager and uninstalled the driver, then MS automatically searched and installed it, but it is still doing the same thing.
#4 _*Creative Insanity_*
Posted 15 September 2007 - 12:05 AM
What was actually the problem with Vista? I would of thought if it came with Vista it would be built for that OS better.
Maybe put Vista back on and I know there is something on P2L to remove the annoying things in Vista that many do not like.
Worth a shot ah.
Sorry the SP2 thing never worked.
Worth a shot ah.
Posted 15 September 2007 - 12:20 AM
I actually think the performance is much better with XP, aside from the usb problem. I can live with that if I don't have to live with all the things vista does.
#6
Hrmm.. without thinking about your OS it looks like your computer only has USB 1.0 ports.. but I assume any computer which had vista on it should be all 2.0 =\
#7
Posted 15 September 2007 - 12:30 AM
Yeah, they are 2.0...
#8
Posted 15 September 2007 - 12:37 AM
Have you tried the patch update? http://www.softwarep...s/winxpusb.html
#9
Posted 15 September 2007 - 12:47 AM
I was feeling good about that Donna, but when I tried to install it said it was only for SP1, and I'm on SP2.
#10
Posted 15 September 2007 - 12:51 AM
strange as it even states for SP1 and SP2, only other thing I can think of is to run a scan of your system using Microsoft's Windows Update double check that you have all the needed patches, then try again.
#11
Posted 15 September 2007 - 12:54 AM
AH! I kinda feel dumb now. I went back into Device Manager and realized that there were 2 occurances of USB. I had overlooked the problem USB device. I uninstalled both drivers then plugged in a USB device and Windows automatically downloaded the newest drivers for the USB. So its working at 2.0 full speed now.
Thanks for the help
Thanks for the help
