how do i get lines to go from fat to a point? '
thanks
corel x3 line help
Started by zoom4267, Sep 15 2007 06:44 PM
2 replies to this topic
Posted 15 September 2007 - 06:44 PM
Posted 18 September 2007 - 09:31 AM
Try changing the outline/stroke size.
Posted 18 September 2007 - 09:40 AM
I use Corel 12, but i'm sure it isn't that much different to Corel X3.
Try using the Artistic Media Tool, try pressing "I" it should bring it up. Then just play around with the settings. There should be a preset for a line that goes from thick to thin.
