redirection problem
3 replies to this topic
#1 ap_
  • 31 posts
Posted 09 December 2007 - 04:29 PM
i have this code:
$user = $_GET['id'];
$option = $_GET['opt'];
if($option = "info"){
	include('usdata.php');
}elseif($option = "upload"){
	require('doupload.php');
	die();
and it just keep loading usdata.php only , any ideas?
I use both require() and include() fuctions and keep it doing the same.
The links are <a href="folder/?id=sm&opt=nn"></a>
Any help would be gratefull.
Thanks by the way!
Edited by ap_, 09 December 2007 - 04:33 PM.
#2 Demonslay
  • 970 posts
Posted 09 December 2007 - 04:41 PM
For one thing, this is not redirection, so I don't quite get why your title refers to it as that.
Your problem lies in the fact that you are not using the correct operators in your if/elseif statements. When you use one equal sign (=), you are assigning the variable a value, so this will (almost) always result in returning true, as long as the variable could be correctly set to that value, and that value doesn't evaluate to false. To compare, you need to use double equal signs (==).
So basically your code would be this.
$user = (int)$_GET['id'];
if($option == 'info'){
elseif($option == 'upload'){
	die();
Just simple stuff. :)
Edited by Demonslay, 09 December 2007 - 04:45 PM.
#3 dotbart
  • 141 posts
  • Interests:Webdesign, Webdeveloppement, DJ, ...
you are using only one '=' in your if
wich assigns the value 'info' to $option
should be:
if($option == "info"){
}elseif($option == "upload"){
	die();
#4 ap_
  • 31 posts
Posted 09 December 2007 - 05:15 PM
thanks a lot ure the best.
