SOLVED - Help with PHP Class
No replies to this topic
#1 Killswitch
  • 20 posts
Posted 21 December 2007 - 12:02 AM
Edit - I am such an idiot. I knew all should work. Turns out there is no record for the secid I am trying to get :D
I have written a very small class that I am having problems with. I know the solution is probably infront of my face and an easy fix, but it's really giving me grief.
Class file
class section {
 var $secid;
	   * Constructor
	  function section($secid){
		 $this->secid = $secid;
	   * Get section information
	   function getSection(){
		  $query = "SELECT secid, secname FROM sections"
		  . "\n WHERE secid = " .$this->secid;
		   $result = mysql_query($query) or die(mysql_error());
	  $row = mysql_fetch_array($result);
	  $secname = $row['secname'];
		  return $secname;
	   * Writes breadcrumb
	   function breadcrumb(){
		  $breadcrumb = '<div id="bc">' .__SECMAN__. ' &raquo; ' .$this->getSection(). '</div>';
		  echo $breadcrumb;
 } // Close class
The file calling the class (the class file is called before all functions), this is snippet instatializing the class)...
function delete_section(){
	  if ($_GET['secid']){
		 $secid = trim((int)$_GET['secid']);
		 // Instatiate our section class
		 $section = &new section($secid);
	 printf($section->breadcrumb());
	 printf($secid);
I used printf($secid) to make sure there was something there, and it prints '1'. The breadcrumb prints the constant but nothing using the $secid variable. I've tried setting the var $secid in teh class manually to 1 and still no success. Any help or suggestions?
Edit - Ive even added printf to the $query in the getSection function of the class, and it prints correctly with 1 as the value.
Edited by Killswitch, 21 December 2007 - 12:36 AM.
