I am having problems with people viewing the layout on a larger monitor. The layout shows up on the right side of the screen and I dont want that. Heres a screen shot: http://www.sportzin....-1201905757.gif.
Is there anyway to fix that?
Thanks
problem with larger screen, double layout?
Started by pistonsfreak, Feb 01 2008 05:46 PM
3 replies to this topic
Posted 01 February 2008 - 05:46 PM
Posted 01 February 2008 - 06:42 PM
im assuming you made the image as a background in a table? i saw your other post and you said you used tables so i assumed.. anyway if you did that you have to make sure you specify the exact width you want or else its going to repeat.
On the other hand if you used css then just do:
background-repeat:none;
Posted 01 February 2008 - 07:06 PM
Yeah I set it as the background, so then where would i put the exact width or the background-repeat:none;
Posted 01 February 2008 - 07:27 PM
I put that in there still dont work.
