Forms help
  • Please log in to reply
4 replies to this topic
#1 crushed
crushed
  • 30 posts
Posted 27 March 2005 - 09:54 PM
I have a form, w/ tabs in it, like this:
(tabs)Home|View Records|Add/Delete(tabs)
then a logo, login message, and then password fields..
I need it so that before you login, the tabs (except for home, which you are in) are grey, and in italics. I have seen this in windows forms, and it makes it so you cannot go to it, or click it. Here's what I'm thinking..
1) If txtUsername.Text = "crushed" And txtPassword.Text = "mypass" Then
2) make tabs go where you can click them.
ANy help? THX :P
#2 crushed
crushed
  • 30 posts
Posted 27 March 2005 - 09:56 PM
maybe if
Dim f2 As New form2
(this is guessing here..)
If f2.Loaded Then
LOAD FORM, and make tabs clickable.
#3 Faken
Faken
    Pimpmaster G
  • Admin
  • 5,966 posts
Posted 28 March 2005 - 11:27 PM
Sorry I don't know jack about programming, but what language are you using to code?
Faken
#4 crushed
crushed
  • 30 posts
Posted 29 March 2005 - 06:44 PM
using .net...thx though
#5 peterk
peterk
  • 17 posts
Posted 24 April 2006 - 01:34 PM
hope fully this will help
command1.visible = False
like that and then to make it visible again just make the False equal True
