Inside the flash document I have a text box (var: who)
the AS I'm using is
onClipEvent (load) {
loadVariables("load.php", this, "GET");
Inside the PHP file I'm using the following code to send the data to the flash file:
$user = $_GET['username'];
$person = "Username: $user";
echo "who=$person&";
This doesn't print anything!? But if I change the value of $user to 'something' and not $_GET then it works perfectly. Am I doing something wrong? I need to read the value of $_GET and send it to the flash document. I know that value isn't empty because if I view the page itself it shows up, its just not sending to flash. Have I done something wrong?
I would really appreciate some help.
