'setcookie' problem.
3 replies to this topic
#1 outofexile
  • 7 posts
Posted 20 March 2008 - 09:01 PM
I've come across a bug in my custom login system (i've coded it myself), and well it worked for a small while, however all of a sudden, one of the cookies that I use to keep people logged in isn't being set.
The weird thing is, it works for my friend and it works when I use the form on my forum's pages (its on the same hosting etc.)
$check = mysql_query("SELECT * FROM user_info WHERE user='$user'");
while ($row = mysql_fetch_array($check))
$username = $row['user'];
$checkpass = mysql_query("SELECT * FROM user_info WHERE pass='$encpass'");
while ($row = mysql_fetch_array($checkpass))
$password = $row['pass'];
if (isset ($usercook) && isset($enccook))
	include ('sidebar.php');
else
if (!isset ($user))
	writeForm();
else
if ($user == $username)
	if ($encpass == $password)
		if (empty($user) || empty($pass))
			writeForm();
			die('');
		print "";
		setcookie("pass", "$pass");  //gives user cookie with submitted password
		setcookie("user", $user, time()+3600);  /* expire in 1 hour */
	else
		print ("");
		writeForm();
else
	print ("");
	writeForm();
print ("");
print ("");
print ("[url="http:///index.php"]Home[/url]
print ("");
print ("[url="http:///about.php"]About[/url]
print ("");
print ("[url="http:///portfolio.php"]Portfolio[/url]
print ("");
print ("[url="http://forum.php"]Forum[/url]
print ("");
print ("[url="http:///contact.php"]Contact[/url]
print ("");
print ("[url="http:///affiliates.php"]Affiliates[/url]
print ("");
include ('con_log.php');
$usercook = $_COOKIE["user"];
$passcook = $_COOKIE["user"];
$enccook = md5($passcook);
$user = $_POST["user"];
$pass = $_POST["pass"]; //cookie is gathered
$encpass = md5($pass);
function writeForm ()
	print ("");
	print ("Username:
 Password:
 [url="http://register.php"]Register[/url]
Please enter your username and password.
		print ("ERROR: Incorrect password.
		print ("");
		print ("");
	print ("ERROR: Incorrect username.
	print ("");
	print ("");
The 'user' cookie never gets set. I have done a number of tests, and the $user variable does get set, but the cookie doesn't
Any ideas as to what the problem could be?
If you need/want any more information, i'll do my best to provide it.
Edited by outofexile, 21 March 2008 - 06:37 AM.
#2 dotbart
  • 141 posts
  • Interests:Webdesign, Webdeveloppement, DJ, ...
Posted 21 March 2008 - 02:08 AM
Cookies should be set in your header, so before your print Anything (or include..)
Can I ask you, what's with all the:
print "";
Your code is a bit messy aswell, might want to try something like this:
session_start();
//previous code
$qry= mysql_query("SELECT * FROM user_info WHERE user='" . $user . "'");
if(mysql_num_rows($qry) == 1){
	$userinfo = mysql_fetch_array($qry);
	if($userinfo["pass"] == $encpass){
		//credentials are correct
		$sessionID = md5($user . $time);
		setcookie("session", $sessionID, time()+3600);
		$_SESSION["session"] == $sessionID;
		$_SESSION["user"] == $user;
NEVER EVER put username and password in cookies since they can be tracked, sniffed, logged, .... Always try and use a unique sessionID value wich you could link to the user in either $_SESSION or your database!
#3 outofexile
  • 7 posts
Posted 21 March 2008 - 06:33 AM
I'm really not sure about why the print functions are there :S I'll tidy it up now.
Thanks for the info, but with that, on other pages, how do I protect the content, would it be
		//CONTENT HERE
on every page that needs protecting??
And to log out,
setcookie("session", $sessionID, time()-3600);
Edited by outofexile, 21 March 2008 - 06:39 AM.
#4 dotbart
  • 141 posts
Posted 21 March 2008 - 06:44 AM
At first, I'd like to correct an error I made in my previous post:
session_start();
//previous code
		$_SESSION["session"] = $sessionID;
		$_SESSION["user"] = $user;
[b]		//You are logged in from here[/b]
I put double == in assigning the $_SESSION, sry about that :-)
To protect your other pages you could do something like this:
if($_COOKIE["session] == $_SESSION["session"]){
	$qry= mysql_query(\"SELECT * FROM user_info WHERE user='" . $_SESSION["user"] . "'");
		//You can assume the user is logged in place other content here
Logging out could be something like the following:
function logOut(){
	$_SESSION = array();
	setcookie("sessionid",NULL,time()-1800);
		header("Location: index.php"); //Remeber to not print any text before this, since it's header information like cookies!
If you want a detailed guide on how to make a secure login system with databases and everything, reply to this message or PM me, I'll be glad to help you out!
