Ok, i'm using the float property for both headers on my site
Found Here
My problem is that after you shrink the window so much one header drops beneath another.
Any ideas?
Float Help
Started by iwz, Mar 23 2008 12:35 PM
1 reply to this topic
Posted 23 March 2008 - 12:35 PM
Posted 23 March 2008 - 05:55 PM
This is because you have your left and right divs with specific widths. So to fix this you must put your widths into % rather than px.
Also left and right % should not be more than the containers % which was 98%, you also have to keep in mind that you have margins which for the left and right side of your #right, so you have to add that to your over all width.
This is what I came up with to keep you site look as close to how you had it, only using %: Left Width 20% + Right Width 75% + Right and Left margins on the Right div 4 = 99%... That is one larger than your container but it seems to still work in IE 7 and FF 2. If however you see the right header jump under the left header then you just have to reduce the Right width a % point.
This of course can be changed a little bit so that the left navigation is a little bigger.
Here is the code of what I changed:
Hope that helps, getting CSS to behave can be difficult (especially in older browsers).
#header {
width: 100%;
background: #242424 url('headergrad.jpg') repeat-x bottom;
#container {
margin: 0 auto 0 auto;
text-align: left;
width: 98%;
#left {
width: 20%;
float: left;
#right {
width: 75%;
margin: 0 2% 0 2%;
float: left;
#left .gradient {
background: #242424 url('navhead.jpg') repeat-x top left;
border: 1px solid #000;
color: #fff;
font-weight: bold;
padding-top: 6px;
padding-left: 4px;
#right .gradient {
background: #242424 url('mainhead.jpg') repeat-x bottom;
color: #fff;
font-weight: bold;
padding-top: 6px;
padding-left: 4px;
