Some flash help
1 reply to this topic
#1 Suicidale
  • 14 posts
Posted 28 March 2008 - 06:27 PM
I need help with making an opacity changer and line size changer on a drawing application.
Edited by Suicidale, 28 March 2008 - 08:03 PM.
#2 flamereaper
  • 65 posts
Posted 17 April 2008 - 08:29 AM
you need to be more specific as to what you want. that statement was a bit vague.
For example, how do want it to change, are you using a slider? buttons? keyboard input. How does the user activate this change in the drawing application. If you can tell us that then the reast should be simple enough to get sorted.
