Cell Splitting Problem
10 replies to this topic
#1 [mez]
  • 96 posts
Posted 01 April 2005 - 11:26 AM
Well i've designed my site and now started coding/dreamweaver'ing it <_<
Now here's the problem: I'm filling cells and all looks perfect in Dreamweaver:
See here: http://www.imageheav...s/mez/dream.jpg
When I preview it in Internet Explorer: http://www.imageheav...iles/mez/IE.jpg
And when I preview it in FireFox: http://www.imageheav...mez/firefox.jpg
What's the problem? :yoda:
Thanks in advance.
#2 Xanderdude
  • 453 posts
  • Interests:Radio controlled flying and Digital art,Web<br />And a little gaming if im bored
Posted 01 April 2005 - 12:14 PM
Insert border="0" in the <table> tag hope it works
#3 maansson
  • 132 posts
  • Interests:Hmm, not much for Photoshop. Havn't taking time to learn it yet. Use Fireworks to the graphical area. More into coding and stuff. PHP, CSS, Java and of course HTML.
Posted 01 April 2005 - 02:13 PM
If you're using the img-tag in IE, I think you'll need to put a <br> after the tag. Don't know why, but it works for me?
#4 [mez]
  • 96 posts
Posted 01 April 2005 - 07:55 PM
Xanderdude: There are already Border=0 codes in place.
maansson: Which IMG tag? The
MG SRC=
#5 InFnit
  • 822 posts
  • Interests:My interests are my:&lt;br&gt;&lt;br&gt;iidsite - http://iid.outer-heaven.net&lt;br&gt;iidblog - http://iid.outer-heaven.net/blog/&lt;br&gt;iidcommunity - http://iid.outer-heaven.net/forums/&lt;br&gt;P2L - http://www.pixel2life.com
Posted 01 April 2005 - 10:03 PM
Don't split cells. By doing this the cells will increase with the content box which you don't want. Use this:
Try using a new table for every box. Like Content has its one table, so does Navigation etc.
Make a table 3® 1©
In the 1st and 3rd ®s add a table 1® 3© Then work from there :D
And split the middle ® into 3 ©
How do I mine and how I make sure it can strech either way.
#6 [mez]
  • 96 posts
Posted 04 April 2005 - 10:38 PM
What do you mean here:
[/quote]Make a table 3® 1©
And split the middle ® into 3 ©[/quote]
#7 InFnit
  • 822 posts
Posted 05 April 2005 - 01:30 AM
<table>
  <tr>
    <td colspan="3"><table>
      <tr>
        <td>&nbsp;</td>
        <td>&nbsp;</td>
        <td>&nbsp;</td>
      </tr>
    </table></td>
  </tr>
  <tr>
    <td>&nbsp;</td>
    <td>&nbsp;</td>
    <td>&nbsp;</td>
  </tr>
  <tr>
      <tr>
        <td>&nbsp;</td>
        <td>&nbsp;</td>
        <td>&nbsp;</td>
      </tr>
    </table></td>
  </tr>
</table>
#8 [mez]
  • 96 posts
Posted 05 April 2005 - 06:10 AM
Ok, thanks.
#9 maansson
  • 132 posts
Posted 05 April 2005 - 07:52 AM
[mez said:
,Apr 2 2005, 02:55 AM] maansson: Which IMG tag? The
IMG SRC=
There's only one <img>-tag. And often (always) you have a src=" " after.
<img alt="Picture" src="picture.png" /><br />
I ment the <br /> after the picture. But after I posted the reply I checked it up. I got the same thin white line, about 1-2 px high. Don't know how to remove it. Anyone?
#10 [mez]
  • 96 posts
Posted 06 April 2005 - 04:59 AM
My problem ended up being caused by cellpadding.
Just make sure you use Standard view.
#11 maansson
  • 132 posts
Posted 06 April 2005 - 02:03 PM
LoL, something as easy as a cellpadding. Unfortunally that is often the case... :)
