Help ,How to Continue append an open path in Illustrator?
3 replies to this topic
#1 annabella
  • 32 posts
Posted 29 May 2008 - 11:20 PM
I read a guide of Inkscape saying to Continue append an open path by Select the path and start drawing from one of the end nodes with the Pen Tool , so here using Illustator how to do the same ...?? Thanks
#2 Scythar
    Honored X Staff
  • 1,888 posts
Posted 02 June 2008 - 07:31 AM
select the openpath, select pentool (f.ex) go to the endpoint (cursor changes: pen with slash), click on endpoint and just continue drawing.
#3 annabella
  • 32 posts
Posted 06 June 2008 - 09:32 AM
Oh,Thank for your pointing, i made a confusion that the cursor symbol of pen lash with the symbol delete anchor point tool
#4 Scythar
    Honored X Staff
  • 1,888 posts
Posted 06 June 2008 - 01:04 PM
that would be a point with a "minus" symbol ("delete anchor point")
