Hi there.
I made a abstract wallpaper (1024x768) in bryce and yesterday i started rendering.
Well first off all, it still isn't finished! and the % started back at 0% again?? but the whole rendering process is continueing.
SO..my first question is:
Is it normal that the % goes back to 0 but with the rendering process still continueing?
And my second question is:
Is it normal for a render to take almost a day to get to 20% ??
Because I started rendering it yesterday at 15:00. and I left the pc on this night but this morning it was on 20% so it took more then 20 hours to get to 20%..
Please help me out.
My settings are:
Optimization:
-For uniform scenes (grid
-Agressive
Quality:
Super (fine art - AA)
I hope this information is enough and i hope that nyone can help me out.
Need help with bryce
Started by Abbys, Apr 04 2005 10:02 AM
5 replies to this topic
Posted 04 April 2005 - 10:02 AM
Posted 14 June 2005 - 08:32 PM
i've never rendered that big but its possible that Bryce will/can take even longer than a cople of days, i've never experienced that myself, the way your settings are set it looks as if you can't go any faster in the way of rendering
[quote]And my second question is:
Because I started rendering it yesterday at 15:00. and I left the pc on this night but this morning it was on 20% so it took more then 20 hours to get to 20%..[quote]
its possible but what the heck are you rendering? must be something that has a lot of reflections and lots of other things that would take a while to render, there is a lot of ways to make bryce render faster without buying RAM or installing new hardware
Posted 14 June 2005 - 09:29 PM
no its not normal most its ever taking for me to render a pic in bryce was 20 mins and that was a 800x600 so it cant take to much longer with a bigger size. also when it renders it does go back 2 zero% 2 times i think. a first render, a second then aa.
Posted 14 June 2005 - 10:25 PM
What are you pc specs?
You have rendering on superfine, Put it on normal or fine. Change Agressive to normal.
Posted 15 June 2005 - 08:55 PM
Abbys, check your PC specifications by clicking start>run type in dxdiag
#6
Posted 16 June 2005 - 05:30 PM
why not try rendering a simple object to make sure it works
